weird and difficult to find the cause problems - post your case!
Old Jul 27, 2021
Let's see,
  • The civic was having a clunk, clank sometimes when going over bumps. Look here, prod there, nada. well, turns out I finally found the problem... this was on the upper side, closer to the frame. very hard to spot even lifting the car, no tires...
  • my miata was having weird handling issues, inconsistent behavior but could not find the cause... Just when i bought it, i hit a sidewalk sideways (don't ask). well, this one is the bolt that connects the upper arm to the frame.... under cornering, it moved slightly and changed the suspension geometry slightly... only the head and the nut are visible, so I only found out when i disassembled the arm...
  • clunking noise when car was subjected to any G's in any direction. months looking for the cause.
it was an effing glass coke bottle that got under the rear seat... Grrrr!
  • electronic peep noise. try to find what was making the noise. aftermarket alarm? something under dash?
no, it was an effing wrist watch that fell between seat and central console by previous owner...
Shoot away your weird causes!
Old Aug 27, 2021
Re: weird and difficult to find the cause problems - post your case!
Stolen from @ezone , LOL!
Originally Posted by ezone
Those weren't frequent failure items IMPO. Checkover the wiring for damage
I deal with a lot of damaged wiring here ....Critters LOVE LOVE LOVE to gnaw car wiring.
Ever notice any evidence of rodent activity? Seeds or food kibble laying around, (Kinda like kids imo) Food stashed.... sliding or rolling noises when the hood is lifted, wads of nest material, or turds..
Actually meeting a furry vandal in the car can get pretty dang exciting too,
I've been face to face with live squirrels, chipmunks, mice,
a rabbit who kept chewing injector wires when the hood was opened, ;
a raccoon snoozing when the hood was opened (looked up at me like 'aw man plz turn off the lights')
a rat who made a honda van 3.5 engine its home
Customer scheduled to return van the next day to fix one wiring problem, but this rat got all ambitious n chewed a completely different bunch of wires overnight. And I found it staring at me from its hiding spot.
when i scared it out from under under the intake manifold it ran across the shop straight to a MDX (with the same style engine) and hid under the intake manifold.
Aaaannd then things started to get really interesting.
Old Sep 3, 2021
bugbitten's Avatar
bugbitten is an unknown quantity at this point
re: issues after replacing CPS [solved, bent pins]
Moderator note: Copied [by @sdaidoji ]
@bugbitten , you got the prize
Your post got the honor of being in this thread, so we copied it here. It is unexpected cause
Let us know if you want us to remove this from here, but I started the thread to show that somethings are just... not what they appear or something in the specific car is different and we need to really investigate what went down - all the threads we have in the title saying that it is unique are actually well known issues, BTW...
Mystery solved! I guess I was ham-fisted putting it back together and bent two pins. Big sigh. I'll probably have to wait until the morning to get it back together, as the sun's going down, but maybe now the car will actually run decently with no codes.
Old Sep 18, 2021
CivicChoice's Avatar
CivicChoice is an unknown quantity at this point
Re: Running issues after exhaust header / cat change
Moderator note:
Copied from this thread, since this is the first time i ever seen this happen. Thanks, @CivicChoice
https://www.civicforums.com/forums/3...-change-2.html
Found a/the problem... all of the teeth on the timing gear are sheared off!
I'm beginning to belive this isn't a 30k mile engine. ..
Old Sep 18, 2021
oh what the hell. That's a new one. CKP sensor freaking the hell out
Old Jun 15, 2022
losing power
common, sadly, but unexpected answer
Originally Posted by Dice_of_Mars
Wow **** complete oversight, me being an idiot trusted the ****ing guy at the dealership, put an extra quart too much oil, gonna see if I drain some if the problem persists hope I didn't do any permanent damage... I hope this is the issue
https://www.civicforums.com/forums/3...on-solved.html
Old Jun 18, 2022
Brakes
https://www.civicforums.com/forums/3...or-solved.html
Originally Posted by ziddey
Looks like I found the culprit. Pulled a caliper and found the piston rubber boot looking like a balloon. Somehow it maintained enough of a seal to keep all the leaking fluid inside.
Old Apr 10, 2023
https://www.civicforums.com/forums/3...ivic-d17a.html
Old Jul 22, 2023
woah, another weird cause...
Who woulda guess it was tire balance weights hitting the chassis?!?
https://www.civicforums.com/forums/3...ft-solved.html
Old Oct 28, 2023
https://www.civicforums.com/forums/3...ds-solved.html
Old Nov 2, 2023
93IndyCivicGuy's Avatar
93IndyCivicGuy is an unknown quantity at this point
Re: Clunking and snapping coming from front end (2017 Civic LX)
Edit: Copied your post from another thread, thanks, @93IndyCivicGuy
Old post but I will provide my experience with a clunking. Purchased a 2016 Civic Touring, Honda certified 75,000 miles and after a week started getting a clunk from the front suspension, sounding like a bad strut or control arm bushing going bad over any bump large or small. Nothing visible after jacking. Took it back to dealer and the mechanic found in their data base to look for rock(s) in or around the sway bay. he removed the sway bar and applied compressed air to the tunnel the sway bar runs through in the chassis and a small pebble came flying out, about the size of a small almond. The pebble was scraped up from metal contact. Reassembled and the clunking was gone and I'm now @ 80K, driving great.
Old Aug 4, 2024
crowfather's Avatar
crowfather is an unknown quantity at this point
Re: 04 Civic DX, Manual Trans Idle Issues
From Moderatos: Copied from another thread
https://www.civicforums.com/forums/3...le-issues.html
So I think I found the problem, probably need a second opinion though. /s
I gotta hand it to the JB weld / RTV folks. The patch last at least four years, maybe longer.
sentbacktothesu
17
Feb 24, 2016 01:21 AM
xmeeksx
May 13, 2004 01:53 AM
Vinnie
Oct 3, 2003 06:51 AM
neoretromax
Jan 20, 2003 06:00 PM
mwwhonda
Aug 2, 2002 11:12 AM
