Idle Issues If you have idle issues, post here!
Running issues after exhaust header / cat change [solved]
Old Sep 12, 2021
  #31
FRSam's Avatar
Click Here
re: Running issues after exhaust header / cat change [solved]
Where did you get it from?
Old Sep 12, 2021
  #32
CivicChoice's Avatar
CivicChoice is an unknown quantity at this point
Chezboat24
Re: Running issues after exhaust header / cat changeWhere did you get it from?
The sensor? It's OEM Honda $218 or first born male at Riverside Honda. I know they're cheaper online but I'm sick of waiting 2 weeks for every new part to chase this beast back on the road.
Edit: i found a weird thing. The cruise control cable was keeping the throttle plate open about 25% or so making it rev up to the limiter non-stop when started. I disconnected the cable and now it starts and idles,though with the P0335 code intact, and 3500 rev limit.
Old Sep 12, 2021
  #33
I'm going to tear the top off again and make sure the timing didn't skip a beat, maybe double check the valve lash again since it was rather noisy at idle.
Old Sep 18, 2021
  #34
Found a/the problem... all of the teeth on the timing gear are sheared off!
I'm beginning to belive this isn't a 30k mile engine. ..
Old Sep 18, 2021
  #35
glad you found the issue, good luck on fixing it...
Old Sep 20, 2021
  #36
BrotatoChip's Avatar
Super Moderator
How in the heck did that happen?
Old Sep 20, 2021
  #37
I am thinking a lucky rock or bolt got in there.
only 1 of the lower timing cover bolts were connected, the cover was cracked/separated/broken on the other 3
what I don't understand is how the car drove the past 10,000 miles with all this stuff wrong with it and not throw a code
Old Oct 2, 2021
  #38
it looks like my assumption was correct. Something definitely got in there shredded the teeth and exited violently out the bottom left side tearing the lower timing cover and creating a jagged mating surface on the Block
Old Oct 17, 2021
  #39
Epilogue:
Replaced the timing sprocket and lower timing cover, put it all back together and she's purring like a 20 year old kitten.
The exhaust manifold bolt holes had been helicoiled before and will not hold full torque but it did not leak, also had to helicoil a hole for the valve cover and it seeps a little in the corner (didn't replace the gasket I've had enough throwing parts at this thing)
Once you get the crank bolt off the rest is just plugging/unplugging electrical and removing/replacing bolts and nuts. It would be helpful to have a garage and more helpful to have a lift but it is what it is. I may report back with compression numbers but for now I'm done wrenching.
davidebarone
Electrical
Jan 18, 2023 05:02 PM
CivicAK
May 15, 2022 01:43 PM
ZachCivic
Apr 24, 2017 02:30 PM
CIV1C
General
Aug 18, 2013 12:31 PM
