throttle cable adjustment!!
Old Nov 16, 2004
MyK's Avatar
MyK
MyK has a little shameless behaviour in the past
http://www.7thgencivic.com/forums/sh...d.php?t=168120
has anyone done this? does it improve performance?
whats the TB?
Old Nov 16, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Done it. Just reduces the slack on the cable, doesn't make you any faster or anything. TB = throttle body.
Old Nov 16, 2004
skipbarber's Avatar
it eliminates any play your gas pedal has. It really doesnt make a difference in anything. the TB (throttle body) is what the gas pedal is connected to, between the intake and intake manifold.
Old Nov 16, 2004
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
TB, throttle body. the gas pedal is connected to a cable that connects to the throttle body. depending on how much you push the pedal (or pull the cable) determines how wide a butterfly valve inside of it opens.
that flat circle inside of the throttle body is the butterfly valve. when it is opened more, it allows more air to flow through. more air means more gas is injected, more air and more gas = more power, thus when you push the pedal to the floor, you go faster.
i really like this mod. it's easy to do and pretty effective. i say do it. it takes 5 minutes if that.
Old Nov 16, 2004
Overboost's Avatar
Overboost is an unknown quantity at this point
Agreed. Lost the slack and enjoy the quicker response.
Old Nov 16, 2004
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
I did it too. Make sure that nut is really really tight, or it'll slip a bit.
Old Nov 16, 2004
MyK's Avatar
MyK
nice!! I'm gonna do it when i get home from skool tonight! any other mods like this you guys know of?
Old Nov 16, 2004
Mr.Modify's Avatar
made the pedal tight but thats it....nothing to go crazy about.
Old Nov 17, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
can someone put a DETAIL, DETAIL diy on this....i read the diy we have...and still dont understand.
i really really want to do this mod
Old Nov 17, 2004
Blahman2's Avatar
its not hard at all, you only need one adjustible wrench. Don't touch the idle cable. You'll know which is the throttle cable its the one that lets you rev from under the hood. Just losen the nut, then pull the cable as tight as you want it, then tighten the nut.
Old Nov 17, 2004
armieo's Avatar
< My future wife.
Tighten it and then put it up on your mod list in your profile.
Old Nov 17, 2004
Did you read the link above? That's why I wrote it.
Old Nov 17, 2004
dannn's Avatar
unique conformist
dannn will become famous soon enough
i did it too
doesnt do anything but gets rid of the slack in the pedal so that it gives gas right when you press it. not like 2 inches after pressing it.
Old Nov 17, 2004
i seems really easy.....but after reading gearbox's diy, it seems like u can mess things up really bad....im scare
Old Nov 17, 2004
cheukkin's Avatar
cheukkin is an unknown quantity at this point
stock setting is the best imo...
Old Nov 17, 2004
MyK's Avatar
MyK
^^^haha, the brass lever that the cable pulls on, just make sure its in its resting place (at idle) once you'r done tightening the cable. itll be fine.
Old Nov 17, 2004
Skunk2ner's Avatar
stock setting blows, imo. when you push the pedal to the floor, it doesn't seem to be at wide open throttle. just pull a little bit of the cable and tighten it. if you over tighten it, it will just make your idle higher, you can always give it more slack again. it's a piece of cake. dude you're in mission viejo? i could do it for you haha, i'm like 5 minutes away in RSM
Old Nov 19, 2004
familycar's Avatar
you guys are close to me too im in lake forest. i did it too . didnt notice much besides a lil quicker response. you guys are cpe's i have a sedan and i want to run a cpe just for fun. i have 18" rims however and that kinda takes some of my power. but i still have fun with it even though it is my family car. i work in foothill ranch too so im always around the area. you should hit me up so we can run one night. what other mods do you locals have??????
Old Dec 6, 2004
hotrodcivic2004's Avatar
my civic has no boost
be very careful though! that locknut moves very easy and when you tighten the other nut it may move the lock nut a little which DOES affect the tension of the cable. I found out because i could get upto 25....and take my foot off the gas and keep goin 25 and it would speed up....you just want the 2 pieces to touch, not to push....you should be able to pull the black one back....let it go and it shouldnt move the brass piece at all...it also redlines higher after i finished....it'll go upto 7200 now instead of automatically cutting off at 6800.... just FYI guys...also i have an 02 ex auto
Old Dec 6, 2004
exclusive_vtec's Avatar
yup.
Old Dec 6, 2004
2K1Civic17"Gabe's Avatar
The reason the stock pedal doesnt feel WOT is because it isnt. To properly get to WOT, DO NOT ADJUST THE CABLE. I wouldnt touch that myself. There is another way to achieve it, and much safer to do, so you dont not tighten something too much or break something.
Here are the steps:
1)Open your drivers side car door.
2)look under the gas pedal.
3)You may have to pull the carpet down under the gas pedal, but there will be a large black piece that the gas pedal sits on when you push the pedal down all the way.
4)Grab a socket that will fit over the bolt holding it on. If I remember correct, there is only 1.
5)Loosen it, take it off, and if you happen to see others, get them (I did this 3 years ago)
6)the black piece should be loose, take it out, throw it somewhere incase you feel like ever putting it on (yeah right)
6) Put the carpet back on
7)enjoy the new performance.
I would consider this more the proper way to do it. This way you WILL achieve WOT, and nothing was altered in the engine. You will not have too little or too much to reach WOT. This should take you all of but 3 minutes to do, and achieve the same if not more Throttle. It keeps the pedal about 3 inches off the ground. Enjoy, please try it this way, and you will figure it out quick, and enjoy it. The only difference is that I have to press the gas pedal down more, but it seems to be perfect for me, there is no prob with that whatsoever. DO NOT ALSO TIGHTEN THE THROTTLE CABLE D.I.Y. IN CONJUNCTION WITH THIS, OR YOU WILL HAVE A BROKEN CABLE.
This also works with most every car there is. I know saturn and some trucks have one. My friend with a saturn told me about this when I got my car.
Old Dec 6, 2004
jakejham's Avatar
jakejham should not be trustedjakejham should not be trusted
i did it and its not special at all. heh
Old Dec 6, 2004
Duh, youre not getting more HP out of it. If you did what I typed about the black piece, than you might not be pressing down all the way. Slam your gas to the floor till you cant possibly get it any more down, and you will definately notice a nice difference. Just from the sound you can tell more air is coming in. the black piece is what keeps the slack from WOT, no need for tightening anything. as soon as that piece is gone (3 minutes) you will be able to reach its full crappy potential.
Old Dec 6, 2004
Originally Posted by 2K1Civic17"Gabe
... you will be able to reach its full crappy potential.
Old Dec 6, 2004
cheukkin's Avatar
I definitely prefer that one, never touch engine's part and gain performance is the best diy forever. Thx for your input 2k1civic17"Gabe!
Old Dec 6, 2004
CivicsRdBest's Avatar
I'll try them both... whenever I'm not feelin lazy... Anything cheap that'll help my car to be easier to drive everyday will be awesome.
Old Dec 6, 2004
I would not remove the pedal guard. I have reached 100% throttle just by tightening the cable a little (still has slack).
Old Dec 7, 2004
MyK's Avatar
MyK
HHmmmm what the hells a fella to do???
Old Dec 7, 2004
allmotor's Avatar
nor cal 7thgens
i did this diy and gives you better trottle response and i havent had any problems
Tyler93
Mar 20, 2016 09:03 PM
velozp
Dec 13, 2015 11:28 AM
IronFist
Sep 25, 2015 07:13 PM
2.0.0.2
Sep 14, 2015 06:38 PM
Bricoleur
Sep 9, 2015 12:30 PM
