I.C.E. (Audio) & Electrical Upgrades Post all your I.C.E. (In Car Entertainment - Audio) and wiring questions here (Audio, video etc.)
Replace front door speakers - replace speaker wire?
Old Oct 19, 2019
CleMike's Avatar
CleMike is an unknown quantity at this point
Hey guys,
I have a 2017 Honda Civic Manual - basic model.
I am planning to install an amp, subwoofer, and replace the front speakers, keeping the stock head unit.
I have done this before on my old 2002 Honda Civic, but I had an aftermarket radio, so I am new to doing it with a stock head unit.
My amp has speaker level inputs, so I was planning on just tapping into my rear speakers because I don't want to mess with cutting any wires on the stock radio.
Questions:
1.) The guy on crutchfield said I could just tap into my rear speakers for the inputs when I said I didnt want to mess with the radio. He also said I should replace the stock speaker wire when I replace front doors and said that would run to my amp. Is it difficult to replace and reroute the stock speaker wires, would I need to mess with the radio if I do this? Where is it going into the amp?
2.) Is there a convenient wire to tap into for the remote turn on wire?
Thanks!
Old Oct 19, 2019
GolNat's Avatar
Prelude Owner
Re: Replace front door speakers - replace speaker wire?
1.) I don't see why you would need to replace the speaker wire since you are keeping the OEM headunit. It is not changing the amount of power getting sent to the door speakers. Yes tapping into the rear speakers is the easiest place and those taps will go into the "line" input (speaker input) on the amp.
2.) Ignition area. I would use a volt meter and find a wire that goes to +12 when the key is turned. Cigarette lighter (12V socket) would work also as long as it gets turned on with the key and is not hot all the time.
Old Oct 19, 2019
CleMike's Avatar
Exactly answered my questions. Thank you!
Old Oct 19, 2019
GolNat's Avatar
Prelude Owner
You're welcome and good luck on the install
Old Oct 19, 2019
From what I've read, you supposedly get better sound levels if you tap the front speakers. Then again, that's if trying to wire in something like an AudioControl LC2i to tap a sub into the stock system. From what I've also read (been doing a buncha research for my own system), people have had adequate sound levels when tapping the rear speakers. I'm sure it's super audio-philes making a big deal out of tapping front vs rear channels.
pward426
Jul 23, 2009 10:17 AM
316
Mar 8, 2009 06:47 AM
jaycue
May 12, 2008 02:05 PM
BlueBullet
Feb 13, 2003 03:53 PM
PhWanC
Mar 10, 2002 01:24 AM
