Speaker Wire
Old May 7, 2008
jaycue's Avatar
jaycue is an unknown quantity at this point
Speaker Wire
Hi - First post here.
I searched throughout the forums for the answer to this, but to no avail.
I am about to become an owner of a 2004 Civic 2 Coupe.
I plan to replace the stereo system complete with 4 new speaker, head unit and amp.
I've seen the DIY on replacing the speaker - big ups for all the posts actually - been informative.
My question is, should I replace all the speaker wire leading to the speakers? or is it okay if I just reconnect to the factory installed speaker wire behind the head unit?
Thanks,
Jaycue
Old May 10, 2008
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
Re: Speaker Wire
If you are using an external amp to power the speakers (not the head units internal amp) then I would recommend running new wire. Else if you are using the head units internal amp, I personally would not. Thats just my 2 cents.
Old May 11, 2008
redem's Avatar
redem is an unknown quantity at this point
Re: Speaker Wire
you would only change the wiring if it was a really old car (i.e. 92 civic) other than that you won't have to, i'm learning to do install's at best buy, and our pro tech. new his ****
Old May 11, 2008
redem's Avatar
Re: Speaker Wire
knew* lol
Old May 11, 2008
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
Re: Speaker Wire
depends....
if your running an aftermarket amplifier to speakers (6", 6x9's, etc...) with bigger watts then yea...id still do a wire upgrade, and even with the new wiring you can purchase today from Stereo stores is much cleaner then OEM **** imho. the stuff OEM run is just basic wire thats it. The stuff from your stereo stores are oxygen free, etc....
but if its just a typical low powered amp to half *** speakers then id leave the OEM wiring as is.
Old May 11, 2008
BJanzen's Avatar
Re: Speaker Wire
It also depends on where you mounting the amp...If you have it in the trunk, might as well run new wiring.
Old May 12, 2008
jaycue's Avatar
Re: Speaker Wire
Thanks - I will be using an external amp. Thanks for the replies.
Old May 12, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
Re: Speaker Wire
id definetly run new wires. i now i did. but getting the wire through the door molex is a wee bit difficult.
mrwhos
Aug 11, 2015 02:03 AM
carid
Aug 8, 2015 05:05 PM
jpandjf
Aug 3, 2015 05:02 PM
Nalmonte
Jul 22, 2015 09:08 AM
