original The ultimate DX/LX header/exhaust DIY and FAQ
Old Nov 4, 2007
TRIZ's Avatar
Post original The ultimate DX/LX header/exhaust DIY and FAQ
Ask me your questions DX/LX header/exhaust questions!!!
This will be updated as information is needed.
First many people with DX/LX’s want to know what header will work.
First, the EX header wont bolt up to your existing stock exhaust. Second, you WILL loose your cat. Here are your header options if your cool with your peashooter exhaust and no cat:
Kamakazi – part number: ??
OBX – part number: 10-1602-3D
Will an EX header bolt up to the head of an DX/LX engine?
Yes, the bolt pattern on both the D17a1 (DX/LX) and D17a2 (EX) are the same.
So I should be all good right?
No. Just because the header connects to the head, doesn’t mean the other end of the exhaust has matched up- and let me tell you, it doesn’t. The LX header connects at a point several inches lower then the EX header does to the rest of the exhaust.
So what can I do?
You need to find some way to connect it. You have three options:
  1. If you want an EX header and stock DX/LX exhaust w/o cat, then take it to a muffler shop and have them custom weld the two together. You will loose your cat of course, and you'll have to stare at the check engine light every time you drive your car because the sensors wont be taking readings they understand. To avoid this- see O2 extenders / defoulers.
  2. If you want an EX header and stock DX/LX exhaust with a cat, buy a cat and take it to a muffler shop and they will connect the header to the rest of the exhaust and weld the cat in line. This is kind of stupid- see backpressure. You'll also run a check engine light. To avoid this- see O2 extenders / defoulers.
  3. If you want an EX header, and an aftermarket exhaust you have two options.
  • Buy a stock EX downpipe to connect to the EX header, along with some O2 sensor extension cables or defoulers. Specs: It starts off with an internal diameter (ID) of 2.00" and tapers down to 1.70" ID, finishing with an exit ID of 1.85". This is what I consider the best option if you want to avoid buying the RT downpipe (see below).
  • Buy the Random-Tech downpipe from Dezod to connect to the EX header, along with some 02 sensor extension cables or defoulers. This is the best option if you cant find a EX downpipe.
What is a cat back?
Essentially this is a full exhaust from the cat converter in the downpipe on back, including the muffler, and usually includes an inline resonator as well.
What is a downpipe?
The pipe that connects the end of the header to the rest of the exhaust. This will have a cat in it. If there is no cat, it is called a test pipe- these are usually reserved for turbo applications.
Where can I get 02 extension cables?
This is where I got mine: Casper Electronics. (***link updated by admin*** and your get three dif size options for O2 extention cables) I purchased a 24-inch, and a 12-inch because there are two sensors. While I wasn’t able to, I have been told that some have been able to connect one of the first O2 sensors without the 12-inch extender cable. If you want to splice in wire to lengthen the cables thats up to you, but its creates the potential for more things to go wrong, plus the O2 sensor has a specific voltage so a change in resistance can trigger a CEL. I've also found O2 extension cables here: PasswordJDM or Club RSX
Defoulers
First off lets explain the two O2 sensors. The primary is prior to the cat and exists for air/fuel into. The secondary is after the cat and reads for a working catalyst. A defouler pulls your sensor (usually only need this for the secondary) out of the exhaust stream. This is used by people running race headers with out cats, or cats that are non-functioning. With a defouler, your ecu will not throw a CEL (check engine light). Two options are available- straight or angled. With an angled defouler the sensor will pick up less of a signal and may save you from needed an O2 extension cable under certain circumstances. For more info on how-to, check this out: https://www.civicforums.com/forums/7...simulator.html
Will an EX’s exhaust hangers need to me modified in order for them to hang from my DX/LX points?
No. Thankfully no hanger bending is required at all when putting an EX exhaust on your DX/LX. Even the original rubber donut’s are reused.
Hold on, this is going to get technical for a second
Backpressure
Backpressure is basically some sort of restriction on the air volume/exhaust coming out. A good exhaust system has the right amount of backpressure. Imagine if nobody ran an exhaust system- everyone’s car would be super loud and also yield more performance right? Wrong- they would actually loose power due to no back pressure- that’s why exhausts are important tricky little bastards.
  • With more backpressure, you’ll have better bottom end (this means you’ll be able to accelerate better at low RPM’s). More bottom end is best if your staying away from the track and the strip and not driving like an idiot, or if you just want good fuel efficiency why driving in the city driving.
  • With less backpressure you sacrifice bottom end for top end power. This is best if your on the track most of the time. This is best if your on the track most of the time and need power at high RPM’s.
Exploring the stock downpipe
The stock downpipe seems like its 2.25 inches thick, but its really not because its double walled which gives it the appearance that its bigger then it really is. I believe I measured it at 1.75” when I did my swap.
Whats the best exhaust diamater?
A lot of people say the max they would go with out having extensive motor work done is 2.25”, which others will say that 2” is best. The theory behind saying that 2” is best is that its .25” larger then the downpipe, which should be more then efficient.
The whole thing with exhausts is to not bother increasing one section of pipe unless the others after it are increased as well. You don’t want to have a large downpipe that goes to a small mid pipe, then to a huge muffler with a 5-inch tip. The fact is your exhaust will only be as efficient as the smallest. It’s a thin line, and without dyno sheets for both size exhausts from the same car that are tested in the same conditions, there really isn’t any factual proof that I can give you that can back this up.
Sectional exhaust piping
The sectional piping are pretty similar no matter what exhaust system your looking at, size is the only difference. Exhaust systems tend to be much louder without a cat then system with a cat. To counter act this you can purchase a silencer that sits inside the muffler outlet to restrict the sounds but can/will also restrict the air coming out. Regardless if you choose to run a silencer or not, you’re going to be polluting the earth like crazy.
“Whoa cool, a packaged deal!!”
There are a few setups offered as “packaged deals” or “all in ones.” Be weary. Many of them leave you with out a cat converter. You might be tricked to thinking there is one in the system your looking at because the manufacturers like to place a resonator in the place where the cat would traditionally go to trick you. These are called test pipe.
Conclusion
So… in conclusion don’t worry about a 2.5” exhaust unless your boosting or you figure out how to do some seriously amazing NA work. You will be ok with 2.25” piping, that’s what I have- but that’s the max I’d go with. With 2” you’ll be good and will have a little more bottom end, although you’ll get a increase in top end from the stock exhaust but also a hardly noticeable decrease in top end from what your would experience with a 2.25”. Being I am running a 1.75” to a 2.25” I can say that you’ll be fine, although I think you might get better performance if you had a 2” pipe the rest of the way back.
Additional notes:
The DX/LX exhaust has spring loaded bolts that connect the end of the header to the rest of the exhaust system; these are kind of a pain in the butt to reach but they come off eventually.
If your having trouble getting the exhaust hangers out of the rubber donuts, use a little lube that’s not corrosive to rubber, like white lithium grease that you can pick up at Napa like shops.
Jack your car up and get it on 4 jack stands so you can slide under the entire car with out any problems. Double check that the car is jacked correctly so that you don’t crush yourself.
Use extreme caution when loosening the header from the head of the engine. Use a crisscross loosening patter to prevent warping. Do not loosen one nut all the way, and move to the next, this is horrible for your head. If your having trouble loosening the nuts (which was my case), tap/hit the end of the wrench with a hammer. This is a lot better then using all your might to loosen the nuts- I cracked several sockets when trying to muscle it.
Removing your cat is illegal in most states. Also in some others modifying your exhaust is as well. Check your states requirements, before proceeding.
Questions answered:
I keep hearing that you do need an EX sway bar if you're doing an LX to EX exhaust swap, and i hear that you dont. Im doing the cat back, header, and hi-flow cat--will i need one?
You will if you are going to be using the stock cat.. but I couldnt tell you about the high flow cat- I know they are thinner so it might work, but I dont know if they are thin enough. Only way to find out is if you go and do it... if it doesnt fit, then you just need to get an ex sway or an rsx sway.
For you 8th Gen guys
This is all I got for ya. Thank FGcoupe:
On models 06-07' there is no header to mount onto the cylinder head,
instead they have changed this design using an integrated exhaust manifold.
So, this is a single 2.5" pipe with the 2-bed CAT (Closed couple catalytic converter) as part of it. You cannot remove the CAT material but other alternatives would be to purchase the WeaponR downpipe which in this case removes the CAT all together and uses a defouler to trick the CEL.
Midpipe-This is the section of piping that connects the exhaust to the CAT,
Megan Racing has a mandrel bent section to improve flow. This is bolted
to exhaust manifold with x2 springs/bolts.
Old Nov 4, 2007
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
Re: The ultimate DX/LX header/exhaust FAQ
Awesome write up Triz. Now I can just post a link instead of typing that all out like I was doing before.
Old Nov 4, 2007
TRIZ's Avatar
Exactly my thinking!!!
Old Nov 4, 2007
burke420's Avatar
The World Is Yours!
awesome TRIZ!!!
Old Nov 4, 2007
bigainabuilt's Avatar
Runumhard Or Go Home
bigainabuilt is an unknown quantity at this point
Sweet!! +1 for you
Old Nov 4, 2007
mauri503rida's Avatar
mauri503rida is an unknown quantity at this point
this is exactly what i was looking for A+ for ya .
Old Nov 5, 2007
MADMAT's Avatar
MADMAT will become famous soon enough
Cool thread.
Now how about a complete system for a 03 DX?
Is 2" big enough or should I go 2 1/2" It is a daily driver and I like quiet.
The reason I ask about the 2" is because of this ebay item:
http://cgi.ebay.com/ebaymotors/ws/eB...158057994&rd=1
Junk? Good?
If I do want 2 1/2" what header and catback sys is best for me? And where would I put the cat?
Old Nov 5, 2007
TRIZ's Avatar
Well...
I wasn’t able to find that Megan pipe on their site, which is strange- and I wasn’t able to find it on any other site out there either, which raises some suspicion as to weather it really exists for the 01-05 models, however I was able to confirm that Megan has a downpipe for the 8th gen.
The dimensions that I found where: 2.25" inlet, 2.5" outlet, Total Length 36 3/4" with Two O2 Sensor Holes.
That exhaust system will leave you with out a cat converter, because it has a resonator in the place where the cat would traditionally go This is a test pipe. If you wanted a cat, you could buy the Megan pipe and a cat and take it to a machine shop and have them weld it in- just make sure the cat has the correct inlet/outlet size for the Megan pipe.
The sectional piping are pretty similar no matter what exhaust system your looking at, size is the only difference. The muffler looks like it has some issues with it. I would say this exhaust will be very loud without a cat, although it does look like it has a silencer at the muffler tip, which will reduce the sounds, but also restrict the air coming out. This can be a good and a bad thing.
A good exhaust system has the right amount of back pressure- back pressure basically being some restriction on the air coming out. Imagine if nobody ran an exhaust system, everyone’s car would be really loud but it would give more performance right? This is wrong because they would actually loose power due to no back pressure- thats why exhausts are important.
With more backpressure, you’ll have better bottom end (this means you’ll be able to accelerate better at low RPM’s), with less back pressure you sacrifice bottom end for top end power. More bottom end is best if your staying away from the track and the strip and not driving like an idiot, where as more top end is better if your on the track most of the time and need your power while your at high RPM’s.
Now... The stock downpipe seems like its 2.25 inches thick, but its really not because its double walled which gives it the appearance that its bigger then it really is. I believe I measured it at 1.75” when I did my swap.
The whole thing with exhausts is to not bother increasing one section of pipe unless the others after it are increased as well. You don’t want to have a large downpipe that goes to a small mid pipe, then to a huge muffler with a 5-inch tip. The fact is your exhaust will only be as efficient as the small mid pipe.
Now you have to keep in mind that if you go to a huge downpipe, and then follow that with a huge exhaust, your going to be loosing back pressure even though your pipes aren’t becoming restrictive the further back you go. It’s a thin line, and without dyno sheets for both size exhausts from the same car that are tested in the same conditions, there really isn’t any factual proof that I can give you that can back this up.
So… in conclusion don’t worry about a 2.5” exhaust unless your boosting or you figure out how to do some seriously amazing NA work. You will be ok with 2.25” piping, that’s what I have- but that’s the max I’d go with. With 2” you’ll be good and will have a little more bottom end, although you’ll get a increase in top end from the stock exhaust but also a hardly noticeable decrease in top end from what your would experience with a 2.25”. From the system you picked out it looks like the testpipe has a 2" internal diameter, which is followed by 2.25" piping the rest of the way back. Being I am running a 1.75” to a 2.25” I can say that you’ll be fine, although I think you might get better performance if you had a 2” pipe the rest of the way back. Call Megan and verify they make these parts, and if the seller is selling Megan parts, then you should be fine assuming you get 2” or 2.25” piping from the rest pipe back. I’d also want to make sure that silencer is removable.
Old Nov 5, 2007
MADMAT's Avatar
Thanks A LOT man!! Great info.
I have to run a cat because they do visual inspection here in Clevlenad, Ohio.
That may pass though because it resembles a real cat. Hell, I thought it was until you pointed it out.
I think I will order this system. Its complete and the price could be good depending on what I end up paying. Its says "buy it now or make offer".
I think I'll do this with a cold air intake and crankshaft underdrive pulley and call it a day.
I'm not looking for insane power on this particular car but I can't wait to wake it up a little!!
Old Nov 7, 2007
ultimatetuner10's Avatar
Technical Assistant
ultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond repute
just skimming i think you forgot one thing. the sedan bumper on our car has a small cutout at the bottom, but the coupe has a larger one. i believe coupe exhausts hang slightly higher than sedan so they sit flush with the bumper. therefore, on the sedan, a coupe exhaust will either need extended hangers, or the sedan bumper will have to be cut to accomodate the higher angle of the coupe...this is just what I heard and managed to assumingly put together in my head so double check before you put it into the main post. also, do a bit of info about o2 defoulers as we were saying in the other thread. il put this thread on my desktop and check it daily (cause i know i wont find it otherwise unless its stickied) and try to help you respond to questions
by the way
HAVING NO CATS IN MOST STATES IS ILLEGAL, AND WE DO NOT ASSUME ANY RESPONSIBILITY FOR YOUR MODIFICATIONS. THIS IS WRITTEN AS ONLY A GUIDE. PLEASE REMEMBER THAT REMOVING YOUR CATALYRIC CONVERTER IS NOT ROAD LEGAL, SO BY DOING SO YOU ARE MODIFYING YOUR SYSTEM ON YOUR OWN FREE WILL
i duno how its really supposed to sound, but i dont want someone getting a ticket for their exhaust and then trying to blame you and saying that "he told me so"
Old Nov 7, 2007
TRIZ's Avatar
Good point. I'll try and sticky this somewhere if it isnt already. Edits will be done in the next few days being I'm too busy tonight for this.
Old Nov 7, 2007
Technical Assistant
lol i dint even notice you were a moderator....PM me, I have always wanted to be a mod for a site if you need someone, i can help...im goin to sleep now il see if I can write up something about defoulers by thursday afternoon
Old Nov 15, 2007
pikuko's Avatar
pikuko is an unknown quantity at this point
Hey TrIZ I am trying to do the same thing that you explained. My question to you will be is that how long should I buy the extenders 12"" 24"" or 36"" I am planning to put my cat converter in the same place as the ex model.
Old Nov 15, 2007
speedfoos's Avatar
Also remember the back end flange at the rear of the cat shrinks down to 1.75" again. Here's a pic of it:
And a picture of the stock double-walled downpipe. Honda's padded bra.
Old Nov 15, 2007
The first o2 sensor doesn't need one if you stretch it. Get a 24 inch one for the second one. I got 12 and ended up having to extend it more.
Old Nov 15, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
i didnt see this thread indicating a specific generation so...
ill add to this thread with the 8th Generation DX/LX/EX models.
Midpipe
Old Nov 15, 2007
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
thank you so much triz i have check engine light becuase i have a EX Exhaust on my LX and the 02 Sens dosent reach i was going crazy looking for that 02 sensor adapter <333 Triz Itstriz bitches.
Old Nov 15, 2007
speedfoos's Avatar
Can't you just lengthen the O2 sensor wires by splicing in a longer piece (well, four of them) of wire?
Old Nov 15, 2007
TRIZ's Avatar
Thanks FG, I'll add that in.
Boxcar- haha, no problem- thats why I made this faq!
Frankie- I tryed to strech mine, but it was just a tad too short, and I thought it would break eventually. Maybe you'rs were more sreached out due to more exposure from heat.
Clint- you could splice in wire- I'll add that. I wanted to stay away from that just to take a cleaner approach to the swap, and not have to worry about if my wires were holding together, and water attacking them, or connectors melting and stuff like that. Do you have any better pictures of the double walled downtube, and are the diam numbers I posted correct?
I'll update this faq to include all the points discussed after the first post. I'll also try and take some pictures of how the extender cables and how I kept them from getting burnt.
Old Nov 15, 2007
at school i was taught to not do that....reason being...the 02 sens has a specific voltage any resistance can change it and trigger a CEL....i think thats what i learned lol
Old Nov 15, 2007
TRIZ's Avatar
^ added.
Updated, with exception of defouler/sim box and pictures.
Old Nov 16, 2007
speedfoos's Avatar
I'll take some more pictures and give some better measurements when I get home from work tonight Triz.
Old Nov 16, 2007
TRIZ's Avatar
koo koo.
Old Nov 16, 2007
MADMAT's Avatar
Still looking for a complete bolt on 03 DX header, cat, catback system.
Even if I have to piece it together.
Once I find a header, hi flo cat and cat back I guess I'll have to find a welder.
This is hard man!!
I guess I need to use a header with a downpipe and then add the cat in somewhere else, right?
Old Nov 16, 2007
speedfoos's Avatar
Easiest way to do this, like Triz said, is buy an EX header and catback exhaust.
Then go to Summit Racing and buy 2-1/4" inlet/outlet Magnaflow hi-flow cat. It's a real cat (not a test pipe), is OBD-2A compliant and costs $70. While you're there, buy a 4' length of 2-1/4" pipe ($10-12) and a 2-1/4" formed flange for $5 (P/N: WLK-31885) .
We're at $85 plus shipping right now.
Then head over to Mandrel Bending Solutions Ebay store (Click this), buy these items:
1 piece of 2-1/4" U-bend pipe - $12
1 three-bolt 2-14" flange - $4.25
1 two-bolt and 1 three-bolt gasket - $6 ($3/each)
1 oxygen sensor bung for your post cat sensor -$4
1 L-shaped hanger - $1.76
That's $33 plus shipping from Mandrel Bend Solutions. The whole new, truly 2-1/4" downpipe and real high-flow cat has just cost you $120 plus shipping for the parts. You will reuse those spring bolts already on your car.
Now take your new EX header, catback system, and box of exhaust parts to the nearest non-chain muffler shop. Point to the box of parts and the car and say, "I want all this stuff on my car, and I want all the stuff that's currently on my car put in these boxes. I'll be back in two hours, here's $150."
Go stuff some food down your gullet, have a beer, and then come back to your brand new, **** sounding exhaust.
I'll get your pics in a second Triz. I'm pissed off at the car and don't feel like going outside right now.
Old Nov 16, 2007
speedfoos's Avatar
OK Triz, here you go.
This a shot of the stock exit flange on the EX catalytic converter. The inner diameter of the flange is 47mm, aka 1.85".
Here are two shots of the Honda padded bra. The first shot is looking down the inlet, where the two bolt flange was that mates up to the header (I cut mine off). This starts at 53mm ID,aka 2.08", and then quickly tapers down to the doublewalled soda straw pipe you see in the second shot. The ID of that second pipe is 43mm, aka 1.70".
Pretty restrictive. Bottom line is that unless you get rid of the stock EX downpipe, your 2-1/4" catback exhaust isn't going to do jack for you. Buying the parts and having them welded up, while it may not be cheaper, will definitely eliminate the stock soda straw exhaust restriction.
Old Nov 16, 2007
TRIZ's Avatar
^ well its only restrive to a massive exhaust pushing turbo'd D series mean boostin man like yaself. Well, we both know that statement isnt total correct. I'd love to be able to dyno test all these parts myself and find the optimal size, but thats not going to happen due to money. I saw some homemade dyno videos at one point where the guy was dyno'ing his car in the garage- I've been looking for a place to purchase that, or at least a price list. I can only find the industrial type dynos where you have to construct your garage around an underground pit, or the above ground ones that are at least 4,000 bucks not including the above ground platform needed to actually use it.
It starts off with an internal diameter (ID) of 2.00" and tapers down to 1.70" and finishes with an exit ID of 1.85". Will add. I believe the currecy you suggested was high fives right (thats what your sig said yesterday)- *high-five!*
Old Nov 16, 2007
speedfoos's Avatar
LOL - you can get those sig things at factorizer.co.uk. The message changes every 60 seconds. My favorites so far are "speedfoos only needs one chopstick" and "speedfoos was caught ridin' dirty"!
Glad I could help out!
Old Nov 16, 2007
MADMAT's Avatar
Thank you man! I just printed that out and my homework is done.
I'll be doing exactly what you said!!
Old Nov 17, 2007
speedfoos's Avatar
You're welcome. Rep is a good way to say thanks. It's this icon:
