Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
B18a1 build tensioner issues
Old Jan 14, 2023
Penfambam's Avatar
Penfambam is an unknown quantity at this point
So I've built my B18 A1 motor with all the upgrades you can think of including Hypertech dual valve springs which Maybe part of my issue I'm not sure I have the motors all done complete installed set the timing to start the motor fine at idle I start to drive when I get on the gas tensioner comes loose every time even after being tightened and torqued to spec it still comes loose every time is there a remedy or aftermarket upgraded tensioner pulley spring to not let it come loose need some help here
Old Jan 14, 2023
Re: B18a1 build tensioner issues
can't make it from your post, what is loose?
Old Jan 15, 2023
Colin42's Avatar
Loctite the bolt.
Old Jan 15, 2023
Penfambam's Avatar
Okay so by loose I mean the belt slack... the tensioner spring on it stretches the spring out Beyond its capabilities to where it's no longer spring and the bolt it doesn't come loose but but the tensioner pulley shifts even though the bolt still torque to spec I've checked the bolt after it's still torque to 40 yet the tensioner slides which loosens the belt giving too much slack witch in turn leads to jumping timing
Old Jan 15, 2023
Penfambam's Avatar
I've tried Loctite to no avail
Old Jan 15, 2023
Colin42's Avatar
Try a washer under the head of the bolt
Old Jan 15, 2023
Penfambam's Avatar
Tried the washer under the bolt doesn't change it I even try to locking washer under the bolt same outcome
Old Jan 15, 2023
Penfambam's Avatar
I've even tried different tensioner pulley Springs that were a lot stronger than the stock one and still the same outcome it stretches the spring
Old Jan 15, 2023
Colin42's Avatar
What brand of tensioner?
Old Jan 16, 2023
Penfambam's Avatar
Stock pulleys mostly but the springs I've tried a multitude of um to no avail
Old Jan 16, 2023
Colin42's Avatar
Try contacting the company that made the performance parts you put on and see what they suggest.
Alfie17
Jul 23, 2018 06:58 PM
Tutty6
18
Aug 31, 2017 09:37 PM
Rlss
24
Feb 26, 2016 09:42 PM
coupedeill
Sep 28, 2012 08:49 PM
wetpinkpants
Oct 30, 2010 09:37 PM
