Log In
Register
Forums
Honda Civics by Generation
11th Generation Civic 2022+
GENERAL
HIDs and Retrofitting
Wheels and Tires
Detailing
MARKETPLACE
the *new* Civic Marketplace
Buy, Sell, & Trade - Archive
Transaction Feedback
OFF TOPIC
Photography & Videography
Legal Questions and the Law
LOCAL/GEOGRAPHIC FORUMS
California
Mid West
South
North East
Mid Atlantic
Canada West
SITE STUFF
Site News
Site Tips and Tricks
Gallery
Tools
Car Payment Calculator
Tire Rim Calculator
Vin Decoder
Members List
Live Feed
Marketplace
Vendor Directory
Become a Vendor
the CivicForums Marketplace
New Posts
View Dark Mode
Log In
Register
Threads
Google
Threads
Posts
Advanced
View First Unread
Log In
Register
Dark Mode
Contact Us
Manage Preferences
Archive
Advertising
Cookie Policy
Privacy Statement
Terms of Service
Your Privacy Choices
Affiliate Disclosure
Log In
Forgot your Password?
Terms of Use
and
Privacy Policy
or
Login with Facebook
Parking Brake Help Needed
Notices
Post Wheel, Tire & Brake related modification information and/or questions here
Subscribe
VanHalenRules
Howdy everyone! I recently bought a 1994 hatchback civic DX from a friend of mine. The car was converted to rear disc brakes before my friend got it (also a b18 swap, for some side info), and he did mention something about the parking brake, but wasn't too specific.The car sat in his driveway for about 6 months before I got it (although ever since we gave it a quick jump and started it there, it has had no problem starting and runs perfect). Anyway, I am looking to register it fairly soon, and I wanted to just do an overall check on the car and make sure everything was good to go and will pass inspection. Unfortunately the parking brake does not stop the wheels at all, and I even tried tightening the cables behind the brake lever and made it so it takes a lot of strength to pull it up. Both wheels spin exactly the same as they normally do when I spin them by hand with the car jacked, literally nothing changes with the lever pulled up. I want to buy both new cables and put them in myself, but I'm confused as to what exact model brake cables I need considering it was a rear disc conversion. Also confused as to which site to buy them from if I can find out the right ones to look for. I usually have been looking for most car stuff on
www.carid.com
, and they have had almost everything else I am looking to get for the car except parking brake cables. So I started looking on ebay and I haven't bought anything from ebay for at least 11 or 12 years I think.... I don't know what sellers to trust, and I don't know what other sites will have the cables I need. Any help figuring it out would be greatly appreciated.
Some pics if it helps:
https://imgur.com/lznnYmV
https://imgur.com/5IlmfXq
https://imgur.com/jpM0HPg
03:07 AM
Like
VanHalenRules
View Public Profile
Find More Posts by VanHalenRules
View iTrader Profile
08-08-2018
sdaidoji
Received 1,450 Likes on
339
Re: Parking Brake Help Needed
we don't have much on older civics... nor many that is knowledgeable about them...
but we do have for the 7th gen cars.
it will mostly depend on which car the rear suspension comes from, and see if that car cables will work or not
some reading on the 7th gen - maybe something is similar (or not)
https://www.civicforums.com/forums/4...elled-out.html
https://www.civicforums.com/forums/4...1-01-05-a.html
Like
sdaidoji
View Public Profile
Find More Posts by sdaidoji
08-08-2018
RobertD
78
i would start by removing the rear brake rotor/caliper. you need to see what you bought, and if it's actually hooked up correctly.
you may have small parking brake DRUM assembly inside the center of the disk which may or may not be intact or adjusted. people like to do things half ***, you need to know what you're working with. you may have the disk brake stuff intact and working, and the parking drum innards missing completely.
you might also have the screw in self adjusting calipers that are out of adjustment. it's been a while, can't really remember how those brakes operate.
this is how i remember doing 1991 crx si disks:
You Tube
it's been a while, can't really remember how those particular brakes operate.
post a pic when you get it apart.
after
you get the rear brake adjusted properly,
then
you move on to the cable.
10:47 AM
Like
RobertD
View Public Profile
Find More Posts by RobertD
08-08-2018
VanHalenRules
I did think maybe the cables are good, but something in the calipers or rotors weren't engaging just for the parking brake. I just thought cables because the main pedal brake system in the car seems to function the way it's supposed to. The cable lines all look like they are good from the outside, so I thought maybe stretched cables or something. I'll go out and try to remove the calipers and inspect it, and probably take pics.
Like
VanHalenRules
View Public Profile
08-08-2018
RobertD
78
Quote:
Originally Posted by
VanHalenRules
............. and he did mention something about the parking brake, but wasn't too specific.
before you bother doing anything, if he's a decent friend i recommend you pick his brain on this. he may know exactly what the issue is.
Like
RobertD
View Public Profile
08-08-2018
Colin42
Received 1,131 Likes on
192
Rear disc swap probably came from an integra or a si
Like
Colin42
View Public Profile
Find More Posts by Colin42
08-09-2018
VanHalenRules
https://imgur.com/a/bNFqfw3
Ok I spent some time today checking out some youtube videos and found one of someone taking apart an Integra brake caliper. This is the video:
You Tube
.The way the brake cable connects to the wheel area is pretty much exactly the same as it is on my civic (just the pin (yellow arrow in my picture) was different) and I went out there and sprayed some WD40 on it and got it to wiggle a little. When I went in the car and pulled the brake lever, I went back out and felt that spot and the cable was really tight and didn't wiggle at all... So it seems it's not the cables, but it's the part with the spring on it that seems to be rusted frozen (white arrow in my picture). I'll take another look at it tomorrow and see if I can get it moving. Also even though I wasn't able to take the caliper off to remove the rotor (e-brake cable won't let me take it off unless it's removed first) and check properly for a drum parking brake, I did shine a flashlight into it when I tilted it out a tiny bit and it doesn't seem like there is a drum system inside it.
Like
VanHalenRules
View Public Profile
08-09-2018
VanHalenRules
I just came in from working on it and I'm 100% sure the problem is the mechanism under the spring on the calipers. Must have been from sitting for a while after having winter salts and stuff all over it. I took off the entire caliper, and tried the take off that nut that sits under the bracket that the brake cable connects to, but the wrench kept bending the metal on the nut instead of unscrewing it.
https://imgur.com/F7ombt5
https://imgur.com/jYTLPRX
Once again, the cables seem to be tightening exactly the way they are supposed to, but they are not turning the cam thing inside that engages the brakes. Should I just accept defeat and get new rear calipers? Or would there be a way to get that specific piece apart and replace the parts inside?
Like
VanHalenRules
View Public Profile
Subscribe
Parking Brake Adjustment
tekcap
Brakes
10:57 AM
DIY: Parking Brake Adjustment
NightHawk04
Brakes DIY
09:25 PM
Where is the E brake adjustment Nut...?
brags
06:30 PM
Parking Brake Not Working
sawdust_tom
Wheels and Tires
10:16 PM
Brake Groan
Sparty
04:55 PM
Back to Subforum
View Next Unread
New help with aftermarket rim size
Show Printable Version
Email this Page
Advanced Search
Email this Page
Advanced Search
Posting Quick Reply - Please Wait
Quick Reply:
The following errors occurred with your submission
Okay
Quote message in reply?
Closed Thread
Share
Facebook
Twitter
Reddit
First
Prev
Next
Last
03:51 PM
LinkBack
LinkBack URL
About LinkBacks
