Emissions stuck in monitoring
Old Sep 28, 2018
EK9Fraile's Avatar
EK9Fraile is an unknown quantity at this point
So I recently bought a 2000 ex coupe off the side of the road and she drives great. No problems what so ever, but for some reason I can not get the emissions to complete their test. I took it to Honda and they cleared the whole system and reset the electrical system and told me to drive it (the whole constant speed thing). I drove it roughly 2000 miles and even did Honda drive cycle several times and still nothing!! Can someone please help me, I tried everything! The emissions are still in monitoring
Old Sep 28, 2018
Colin42's Avatar
Re: Emissions stuck in monitoring
all of them or just a couple?
Old Sep 28, 2018
EK9Fraile's Avatar
There’s 4 of them, catalyst, evap, o2, and I forgot the 4th, I would have to double check
Old Sep 29, 2018
Colin42's Avatar
Misfire maybe? Do you have a scanner of your own you can check with? Seems really weird that they would take so long to reset, evap takes a while but everything else should set fairly quickly. Unless the ecu is failing, but I would try a different scanner.
Old Sep 30, 2018
readiness should be in 100 miles, if not cleared, something is going on
Old Sep 30, 2018
EK9Fraile's Avatar
Right!? I used several scanners my uncle has including Honda’s technicians scanner and they all read the same thing. I was thinking about replacing the ecu, would that help any?
Old Sep 30, 2018
Colin42's Avatar
Worth a shot but I would try to borrow one off a buddy before I spend any money
Old Sep 30, 2018
If you know the exact conditions needed to get the computer to run all of the monitors and have space to do it with no other traffic (LOL!), the drive cycle can be finished maybe as quick as 15 minutes.
Does it never ever run those monitors at all, or does it run the monitors (and pass) during a drive but then reset to incomplete after you shut the engine off?
Does the PCM lose its memory after the key is turned off?
Is the back up fuse blown? Has someone done some creative wiring?
asc2000
Engine Swaps
Sep 26, 2018 01:01 PM
Rushracing
Jun 4, 2018 06:41 PM
mikiecivie
Mar 30, 2012 04:29 PM
rjddjcsrj
Jan 16, 2011 02:28 PM
