emissions test?
Old Sep 18, 2010
rjddjcsrj's Avatar
rjddjcsrj is an unknown quantity at this point
Unhappy emissions test?
i went today to get my emissions tested to register a 2000 civic si i just bought and it said i had the error codes P0122, P0113, and P1337. he said the first two he thought were loose wiring and i could probably fix and he said the third was a honda specific problem and he wasnt able to look it up. any idea what those problems are and how i can fix them? i dont know to much about mechanics but if i could fix them myself and save some money that would help
P.S. on the test is said my car model year was 1999, but on the title it says 2000....?
thanks any help would be appreciated
Old Sep 18, 2010
Olliemo's Avatar
Olliemo is an unknown quantity at this point
Re: emissions test?
I don't know about the error codes but with the whole car year thing, that probably has to do with how your car was built in 1999, but it's the 2000 model. Like my car is a 2002, but it was actually manufactured in 2001.
Old Sep 18, 2010
MelJ's Avatar
Trance Addict
Re: emissions test?
For that last code:
http://www.clubcivic.com/board/showthread.php?t=125972
A few replies down.
Old Sep 18, 2010
rjddjcsrj's Avatar
Re: emissions test?
Originally Posted by MelJ
For that last code:
A few replies down.
sweet thanks a lot that helped my question now is i have an aftermarket ECU installed, could it be that this component is working fine its just the ecu or a wire to the ecu that is not connected?
Old Sep 18, 2010
MelJ's Avatar
Trance Addict
Re: emissions test?
I honestly couldn't tell you. Sorry. I only know a handful of things at the moment about cars. I just figured if I threw that on here, that someone could work from that and help you, which I'm sure will happen.
Old Jan 16, 2011
Olliemo's Avatar
Re: emissions test?
not sure on that one either i don't know a whole lot. i would search around on here otherwise maybe pm some ppl that answer alot of questions under the "electrical" part of the forum. or make a new post with your new question under the "fix it" forums or the "electrical" forums on this site.
Civic15
18
Sep 19, 2017 07:48 PM
Uan
Aug 23, 2015 03:03 AM
RIPSAW
Aug 16, 2015 12:14 PM
martinsmartin
Aug 15, 2015 07:34 PM
USCGBM
Aug 12, 2015 04:22 PM
