Will not having a clamp on the fuel line to the manifold cause acceleration issues
Old Jun 17, 2018
Chrys's Avatar
Chrys is an unknown quantity at this point
Ill give it gas and it doesn’t pick up how it should in high rpm’s. Like I’ll put the pedal on the floor and it won’t do anything but accelerate slowly it won’t rev higher or push out any louder sound like it’s accelerating. I don’t have a clamp on the gas line to the intake manifold will that cause it to not pull the pressure it needs? But it revs fine when idling.
Old Jun 17, 2018
Wankenstein's Avatar
Re: Will not having a clamp on the fuel line to the manifold cause acceleration issue
There should be a clamp there and if it were leaking fuel you would smell it all the time. While the car is idling and the hood up you can manually move the throttle pulley by hand to rev the engine while inspecting for gas leak.
Any CEL codes?
Is the engine a Vtec?
Timing belt may have jumped a tooth
Clogged catalytic converter
Old Jun 17, 2018
Chrys's Avatar
I hear a squishy sound when it gave it full throttle but the engine is non vtec and its the fuel return line that doesn’t have a clamp.
Old Jun 17, 2018
Many possibilities for the acceleration issue:
Fuel pump may be weak and not supplying spec psi
How many miles on engine and is it the original catalytic convertor?
Old Jun 17, 2018
Chrys's Avatar
The fuel pump was good when I had the last motor in it...and no catalytic converter.
Old Jun 17, 2018
automatic or manual transmission?
Old Jun 19, 2018
shift down if you have manual.
Jp7
18
Feb 9, 2019 07:22 PM
Eagle
May 21, 2017 04:25 PM
jmath311
Nov 25, 2016 09:27 PM
PacosTacos88
15
Mar 21, 2013 02:54 PM
Cleft_Asunder
Mar 30, 2010 09:28 AM
