‘99 Civic LX automatic transmission...high rpm when changing gears
Old Jun 20, 2018
plumbus's Avatar
plumbus is an unknown quantity at this point
Just bought a ‘99 Civic with 138k on it. Don’t mind my ignorance, I’m a new car owner and trying to learn the ins and outs of these things. The car Needed some tlc got the power steering rack replaced, distrubutor was done recently as well as alternator. I did the blower motor and tires myself, it runs nice and purrs beautifully. Anyway I’ve noticed when driving in D4 which is what I typically drive in at all times that it takes quite a while for the tranny to shift gears, especially above 3rd it seems. I’ll be at roughly 4,000-5,000 RPMs sometimes when shifting at 3rd gear. Checked the transmission fluid, it looks brown but not black. I bought 4 quarts of genuine Honda fluid and plan on doing the job myself, but I’ve heard that it can be risky which has got me bugging that I’m gonna screw something up. I’m worried that mixing Honda fluid with whatever is in there right now will do it.
i don’t know when the fluid has been changed last or If it has been changed at all. Do you guys think it would be safe to change it given the circumstances and will it solve my problem? If not, what could be other potential causes of this to happen, and could things that would seem completely irrelevant to the transmission be causing this issue? Thanks for all the help.
Old Jun 20, 2018
Wankenstein's Avatar
Re: ‘99 Civic LX automatic transmission...high rpm when changing gears
Google: automatic transmission flaring.
Some mechanics feel that if original ATF hasn't been replaced by the 100k mile mark then it's unsafe to replace it. If it were mine I would do a single ATF drain and fill (never use a flush machine) and see if it helps the problem. I also prefer to do a 3x3 atf change (google it) which can be done in a day, weeks, months or whatever the owner feels is best.
Other than that clean the transmission shift solenoids and gasket screen with brake cleaner or simple green.
Old Jun 20, 2018
Drain and fill the fluid. You can't hurt it any worse than it already is.
It will probably hold about 2.5 quarts each time you drain and fill it.
Does the engine run well? Is it low on power? Anemic? Low engine power will make the trans shift late. Have a pro evaluate it?
brianna12
Transmission DIY
18
Dec 1, 2019 04:40 AM
jhammermil2008
Feb 25, 2017 08:41 PM
rtfab
Transmission
16
Oct 30, 2015 07:46 PM
Marcus2thextrem
May 10, 2015 03:08 PM
anephric
Sep 13, 2013 01:02 AM
