1999 Si dome light problem
Old Jun 21, 2018
Garykohl2's Avatar
Garykohl2 is an unknown quantity at this point
i have a 1999 Civic Si. My problem is my dome light won’t turn off when I close the door. I’ve checked the door switches and they are working they way the should. They even turn off the buzzer like they should. However I can’t get the dome light to turn off unless I turn it off at the dome light itself. The on position works, off position works, just not in the door position. It comes on and stays on. Any suggestions?
Old Jun 21, 2018
GolNat's Avatar
Prelude Owner
Re: 1999 Si dome light problem
Remove the cover and inspect the switch. Might just be worn, misaligned or loose.
Old Jun 21, 2018
Garykohl2's Avatar
i did that early and jones it looks fine. I guess it could still be messed up though and I just don’t see it. Need to find a good working assembly and swap it in
hon0405
Lighting
Oct 2, 2020 02:10 PM
joeteran1
Jun 9, 2018 07:49 PM
leftylouie
Nov 2, 2014 09:44 AM
civicplaya
Jan 24, 2009 04:00 PM
JKoffler44
Feb 24, 2007 09:09 PM
