Dome Light
Old Jan 20, 2009
civicplaya's Avatar
civicplaya will become famous soon enoughcivicplaya will become famous soon enough
Dome Light
Okay I searched the forums and couldn't really find what i needed.
For some reason my dome light doesn't turn on when i open my doors, but the light works and turns on when i put it in the on position and goes off when in the off position. It's just when it's in the middle position, it don't come on when i open either door. ('97 2-door)
-thankz
Old Jan 20, 2009
Re: Dome Light
prolly the door nipple broke or is not grounded to the car properly. its the lil black piece that the door pushes on when closed. seems unlikely both sides would fail together so idk. might be something else like maybe a blown fuse.
Old Jan 21, 2009
civicplaya's Avatar
Re: Dome Light
Yeah, both of them are intact and push/release fine. Do you know what the fuse is?
Old Jan 22, 2009
CraigW's Avatar
Re: Dome Light
IIRC the dome light is controlled through the head unit ( I could be wrong ) Has it been changed ??
If the light will work in "ON" then the fuse should be o.k.
Old Jan 22, 2009
civicplaya's Avatar
Re: Dome Light
The light turns on... but the headunit as in?
Old Jan 22, 2009
CraigW's Avatar
Re: Dome Light
Some of the 6th gens have certain items that for what ever reason are wired in with the factory stereo (headunit) If an aftermarket stereo is installed some things can stop working.
Old Jan 22, 2009
civicplaya's Avatar
Re: Dome Light
then that's why, because i don't have the stock head unit. but what should i do then?
-thankz
Old Jan 22, 2009
CraigW's Avatar
Re: Dome Light
The guy told me about the issue when I was at the audio place looking for install parts for my 7th gen.
He said something about leaving the old unit in place hooked up behind the dash (which I find hard to imagine due to space limits) You would need to take the switched power and the speaker wiring loose to hook up the new unit.
Maybe someone on here can chime in on what they have done to resolve the problem.
Old Jan 24, 2009
civicplaya's Avatar
Re: Dome Light
Actually I think they make a bypass module for this, but idk?
Anyone know?
Old Jan 24, 2009
civicplaya's Avatar
Re: Dome Light
But yeah if any of you guys had this same problem, please tell me what you did to fix it. -Thanks
Lopes101
Jun 7, 2015 08:04 PM
beveragemp
May 25, 2015 07:11 PM
twtron
Apr 17, 2015 12:09 AM
meels808
Nov 5, 2001 09:15 AM
TropiKalCiviC
Sep 25, 2001 07:02 PM
