Dome light will not go out after closing door
Old Jul 1, 2014
hon0405's Avatar
hon0405 is an unknown quantity at this point
dome light stays on after exiting car
Replaced my dome light and a door switch in my 04 civic. reg bulb not an led.
after i turn off engine and leave car , shutting door tightly after i leave for some reason dome light will not go out
any suggestions ?
Old Jul 1, 2014
CraigW's Avatar
Re: Dome light will not go out after closing door
The MICU unit in under-dash fuse box provides the grounding path/control (when in "door" position) grounding is provided at switch when in "on" position.
Old Jul 1, 2014
hon0405's Avatar
thanks for the info- do you think replacing the micu will fix this ?
Old Jul 1, 2014
How long did you wait for it to go out?
Hate to ask the obvious, but is the dome switch in the 'door' position?
Old Jul 1, 2014
hon0405's Avatar
nothing wrong with asking any question about issue , obvious or not
I had dome switch in center pole position [ door position ? ] - not on or off [ either end ]
I have another civic [ 05 ] and think the dome light goes out pretty quick after I exit the car
i did not wait too long for the 04 - thought it should go out after a minute or so.
Old Jul 1, 2014
Just looked in service info real quick, I didn't see any time spec for that particular situation.
Does the dome light turn off when you turn the ignition switch (key) on (all doors closed)?
Start engine, shut it off, remove key. Don't open any doors.
Does the light come on when you remove the key from the ignition (do not open any doors)--- then go back out after about 10 seconds since you didn't open any doors?
(Compare these to your other car!) Is your other car identical?
What car is this one? EX/LX/coupe/sedan etc?
Open and close a door......I know the light stays on longer if the doors stay unlocked on most of the cars, and I think if you use the remote to lock it after you close the doors, the light should go out almost immediately.
Do you maybe have one of the doors not closing all the way (or a bad jamb switch stuck on)? Does the horn beep when you hit the fob lock button 3x?
The service manual has a ton of testing for the multiplex and entry light control system. Are there any other mysterious electrical gremlins that may be connected to the multiplex system?
Does the car have aftermarket remote/locks/alarm/remote starter? That might be one of the first things to suspect.
Old Jul 2, 2014
CraigW's Avatar
On my 05 LX the dome would time out after about 4-5 mins if the door was left open.
That would be a good test.
Did your dome light fade out after closing last door when it was operating correctly ??
What trim level are these ?? (may not effect)
Old Oct 2, 2020
Chinedu Onyechi's Avatar
Chinedu Onyechi is an unknown quantity at this point
My dome lights come on immediately I remove the key from ignition (with doors still shut) and goes off after some seconds.
Is this normal? I drive a 2007 Honda CR-V
Old Oct 2, 2020
BrotatoChip's Avatar
Super Moderator
Sounds normal to me. That's how my Civic works.
Old Oct 2, 2020
FRSam's Avatar
Click Here
My TSX is the same. It doesn't sound like it's causing any problems so I wouldn't worry about it.
beveragemp
May 25, 2015 07:11 PM
werdnahall
May 17, 2015 11:37 AM
twtron
Apr 17, 2015 12:09 AM
meels808
Nov 5, 2001 09:15 AM
TropiKalCiviC
Sep 25, 2001 07:02 PM
