gauge cluster light question
Re: gauge cluster light question
is there a document that tells which ones do what??
some of the bulbs that are out. What numbers are they
Carry all bad bulbs into the parts store and see if they can match any of them up.
Then look up your bulbs in an online parts catalog.
http://www.hondaautomotiveparts.com/
Hi, Well I unplugged and tested all 8000 bulbs...fixed (dirty connections) or replaced and now dash is beautiful..THANKS...
Also, the gauge cluster I took out had 108k on it and this one has 160k...is there an easy way to adjust odometer or do I just need to track and disclaim if I ever sell...
thanks again...
thanks again...
Check with your dealer or DMV if they will give you an official mileage change sticker to put in the doorjamb (I seriously doubt they will but I don't know that for sure).
Google for a speedometer repair shop, they can do the work but they may need an official work order copy from a real dealership or shop. Mainly because this becomes a legal matter when it comes to the DMV, and they are NOT going to have anything to do with anything that resembles odometer/mileage tampering.
Actually the easiest thing to do on the 6 gen is just unscrew that 4 screws on the back of the speedo and swap it into your new cluster. If anyone ever asks anything just pretend to be dumb as a sack of hammers.
Not the cluster printed circuit, I mean the board on the speedo itself.
I'm confused now...I got the new cluster (they kept the old one as there was a 5.00 core chg) because of a bouncing speed needle. If I understand what you are saying, I would end up keeping the problem by moving the speed to the new cluster. Or are you (and E) saying the bounce is on the board and not within the speed unit itself??
Clear as mud??
Love the sack of hammers reference...a similar one is "uglier than a sack of a$$holes)....
apologies if that's offensive...
Clear as mud??
Assuming....
The USUAL problem (intermittent operation) is on the circuit board of the speedo head (cracked solder joints can cause a variety of symptoms). If you transferred the original speedo assembly to the new cluster, then you would still have the problem in the speedo.....if that was your problem.
What was your original problem?
The OP was about bulbs, no mention of any speedo problem.
trellex
May 24, 2015 04:39 PM
jimmyfloyd
May 20, 2015 07:06 PM
Ma213802
May 18, 2015 07:01 AM
werdnahall
May 17, 2015 11:37 AM
bahena08
Apr 11, 2015 05:09 PM
