Trouble installing the clutch steel pipe
Hi,
I'm re-installing the steel clutch line (pipe) that goes between the slave cylinder and the rubber hose that leads to the master cylinder (parts #: 46970-S04-000) after a transmission work.
I just can't figure out where the attachment for the pipe goes and how to install the pipe since the angles are really weird. Any tips? If I can even have a picture of where that attachment thing goes, that'd helpful too. Thank you!!!
Re: Trouble installing the clutch steel pipe
There are no tricks. Take the rubber hose end(s) off the bracket(s) and get the threads started by hand if you need to. You can gently bend the pipe as needed too.
Could have been bent during shipping. Make it look like the old one?
Hard to say without being there to see it.
It looks like a simple bracket that anchors the pipe to the (top of the??) trans?
Who took it all apart and lost track of where everything went?
dbagaus
Jun 10, 2015 09:29 AM
pincookie1
May 4, 2015 12:22 PM
