Headlamp on buzzer/chime - Where is it?
Old Feb 2, 2015
Idaho Hick's Avatar
Idaho Hick is an unknown quantity at this point
I tried a search on this topic, but did not turn up anything. The alarm, buzzer, beeper, chime, or whatever it might be called to indicate you left the headlights on does not work in my daughter's 2001 LX Sedan.
I looked for the part online to give me an idea of where the sound should be coming from, but I can't find it.
Does someone know where the alarm device is located?
Thanks in advance.
Mike
Old Feb 2, 2015
CraigW's Avatar
Re: Headlamp on buzzer/chime - Where is it?
Dome light work from drivers door when open ?? Key in ignition, drivers door open warning work ??
Rubber covered plunger switch (drivers side) is 1st place I'd look.
Old Feb 2, 2015
Idaho Hick's Avatar
The dome light was burned out and I just barely replaced that. Are you saying the bulb being out would cause the buzzer to not work?
Maybe I just need to try it again now that the bulb has been replaced?
Mike
Old Feb 2, 2015
Idaho Hick's Avatar
I just went and tried it again. Dome light works fine, but no headlight warning sound.
Mike
Old Feb 2, 2015
The beeper is built into the gauge cluster and is controlled by a CPU.
The same beeper is used for lights reminder, key reminder, seat belt reminder, and maybe more.
Start with a cluster self diagnostic test, the beeper should make noise during the self test.
Old Feb 3, 2015
CraigW's Avatar
Mike
Is it on in "door" setting, with only the drivers door open ??
Do the other mentioned warnings give you a sound ??
Old Feb 3, 2015
Idaho Hick's Avatar
Yes and yes. The dome light turns on when the driver's door is opened, and the beeper sounds when you put the key in and turn to ignition on. I did not realize it was the same beeper. So the beeper works. Just not when I leave the lights on and try to exit the car.
Any other ideas on what could be wrong?
Mike
Old Feb 3, 2015
CraigW's Avatar
Well.......... The MICU is seeing the drivers side plunger switch, and is capable of driving the piezo buzzer. Not good signs.
Will look around.
So...your front and rear markers, tails and license lights as well as nighttime dash illumination is working correctly when lights are on,
Yes ??
Old Feb 3, 2015
Idaho Hick's Avatar
Will look around.
Yes ??
Without going outside and checking all of that (I am currently at work), I can verify that the stop light in the rear deck works with the brakes (I can see the glow at night), and the dash lights are working. If all of the above is on the same fuse, I would say it is intact.
If you need me to verify the other lights as well, I can check those later.
Mike
Old Feb 3, 2015
CraigW's Avatar
Your dimmable dash illumination would be a good clue, (HVAC controls and buttons) and take a peek at license plate lights with them on.
Good news, you can make your own warning system pretty easily with a few parts.
Edit: Not sure what happened with OP but their symptoms were similar to yours. (I'm copytech)
Link ---> http://www.automotiveforums.com/vbul...d.php?t=897150
Old Feb 3, 2015
OP, are you checking for the headlight reminder beep under the correct condition?
Headlights on
Key in ACC, OFF, or removed from the ignition
Drivers door open
(If the door jamb switch is bad, the feature won't be able to work)
From the owners manual:
If you leave the lights on with the
ignition switch in ACCESSORY (I)
or LOCK (0), you will hear a
reminder tone when you open the
driver’s door.
HTH
Old Feb 3, 2015
Idaho Hick's Avatar
Interesting. My door locks also have locked themselves like the folks from the other post describe. In fact, I got the only set of keys I had locked inside when I first got it and could not figure out how it happened. Now I know.
The key in ignition warning does not work either. I just went and loosened and tightened the mounting screw for the door switch without any joy. I will order another door switch and install it. The folks in the other post reported that their dome light would light, but the warning chime would not sound. Somehow swapping driver/passenger side switches fixed it. I can't wrap my head around that, but I will try replacing the switch.
I will let you know how it turns out.
Mike
Old Feb 3, 2015
CraigW's Avatar
Mike
I think your problem is the "key in ignition" is not working as it should.
If you start the car and then shut it off, the second you take the key completely out, the dome light should come on. (A test of that switch)
With your drivers door open, you should get warning sound when key is inserted.
Old Feb 4, 2015
Idaho Hick's Avatar
You had me thinking there for a minute, and you could still be right. But... if I have the door re-lock issue, that would not be dependent on the "key in ignition" switch.
Am I right?
Mike
Old Feb 4, 2015
Go to the car, push the unlock button on the remote.
Do not open any doors.
Just stand there and look pretty, and wait 60 seconds.
Did it relock the doors?
Old Feb 4, 2015
Idaho Hick's Avatar
Yes, it relocks the doors. However... it also relocks the doors if I have opened the driver's side door.
Key in ignition with door open also does not make it chime/beep.
Mike
Old Feb 4, 2015
Then the jamb switch must be bad, as the control unit looks for that to stop the relock timer.
I really only wanted you to understand why the doors can relock on their own. The keyless system did it because it never "saw" the door open.
That same jamb switch must work in order to have the beeper function at the correct times. If it cannot "see" the door is open, it won't beep when you open the door.
Swap a working jamb switch from one of the other doors until you can get a new one?
HTH
Old Feb 5, 2015
CraigW's Avatar
Yes and yes. The dome light turns on when the driver's door is opened.
Mike
Why I did not think drivers plunger.
Both fronts will swap easy enough.
Old Feb 5, 2015
Idaho Hick's Avatar
That confuses me too. It is getting enough of a ground to turn the dome light on, but not enough to tell the computer that the door is open. It is hard for me to understand that. Others seem to have had a similar experience though. I will report back after I put a new door switch in.
Mike
Old Feb 5, 2015
Or maybe you have a multiplex unit taking a poop. The door jamb switch is an input to that unit, and it controls a whole boatload of stuff.
Any other strange electrical faults? Make a list of everything you can think of and see if they all have a common denominator?
Got shop manual that covers testing and diagnosis for the multiplex system?
Old Feb 6, 2015
CraigW's Avatar
iirc the early 7ths did have some known micu issues.
The OP over at AF with similar situation (would imagine the CR-V and Civic multiplex is similar) never came back, and likely wont.
Old Feb 14, 2015
Idaho Hick's Avatar
As promised, I am reporting back on this issue. The new door switch solved the problem. I now get a patterned tone when the key is in the ignition, and a solid tone when the headlights are on (and the door is open).
I examined the faulty switch and discovered that the backside had come loose. I pushed it back together and heard an audible "click" and it stayed tightly together. The plunger also extended further out after this "fix." My guess is that this would have fixed the issue without replacing the switch.
Mike
Old Jan 8, 2021
Joemistishen's Avatar
Joemistishen is an unknown quantity at this point
hon0405
Lighting
Oct 2, 2020 02:10 PM
96 civichatch
Aug 22, 2019 08:54 PM
JKoffler44
Feb 24, 2007 09:09 PM
matescivic
Nov 4, 2005 10:40 PM
Yakkolio
Nov 16, 2002 11:56 PM
