Just hooked up some subs. Question.
Old Sep 8, 2011
iridehonda's Avatar
iridehonda is an unknown quantity at this point
I just hooked up a brand new amp to a brand new sub. As soon as I plugged the fuse in I could see smoke coming from the amp. I quickly pulled the fuse and checked the wiring and the levels (the bass boost was all the way up). Turned the bass boost all the way down, reinstalled fuse, hoped it wasn't blown. Everything is working fine now but should I be worried about the fact that I made smoke come out of my amp?
Old Sep 8, 2011
lowlife9's Avatar
Re: Just hooked up some subs. Question.
uhhhhhhhhhh yeah!!!
Old Sep 8, 2011
iridehonda's Avatar
Would you mind explaining what I have to worry about? Is my amp now doomed for failure in the near future?
Old Sep 8, 2011
lowlife9's Avatar
something burned or melted i couldn't really tell you exactly what happened other then its not suppose to do that obviously . as for future problems i couldn't tell you that either but if its under warranty return it tell them it started smoking maybe they will give you a new one if not maybe buy one of those little fire extinguishers just in case.
Old Sep 8, 2011
iridehonda's Avatar
Lol thanks. I'll throw a fire extinguisher in the car. They won't replace it under warranty unless it was installed by an authorized dealer.
Old Sep 8, 2011
lowlife9's Avatar
where did you buy it from ??
Old Sep 9, 2011
iridehonda's Avatar
ikesound.com
Old Sep 9, 2011
inifiniteblur's Avatar
inifiniteblur is an unknown quantity at this point
what brand of amp? i'll be sure to never buy it. check out onlinecarstereo.com for future buys. got all my **** from them. bangin
Old Sep 9, 2011
7genmarathon's Avatar
7genmarathon is an unknown quantity at this point
Check proper voltage.
Check proper OHM load.
Old Sep 9, 2011
Balzdpr's Avatar
A scene before your eyes
Balzdpr is on a distinguished road
This burning of the amp thing I have seen before. And ill tell you now that that amp is ****ed. What has happened is the bypass switch which is normally controlled by the fuse regulator has malfunctioned. The smoking is not for sure supposed to happen and thats why you have bypass switch connection to the fuses. The fuses are intended to do more than keep you from blowing you friggin car windows out and such crazy stuff. The bypass switch has two , usualy multi chanel connections which are regulated by the fuses so the 12 volt current doesnt fry your ****.
The regulator of the fuse was not operating correctly and the total amount of current went straight to the bypass switch ports. The sound or operation you are getting from that amp is not going to last as the connections are now fused by saudering solution loosly and will melt and come unattached if you crank the bass boost up for any given period of time.
Primaraly, what has happened is you actually have a good amp that is now crap. The fuse isnt blown because the connection or its intended relation to the bypass is not present. I say you have a good amp because that bitch didnt blow from the power conversion without the fuse. It is likely an issue of faulty manufacturing and sucks for you cause you are out of luck.
Now I know this because in 2001 I had the sickest idea of hooking an amp up but forgot to install the fuses first. I had the same burning smell and smoke like you did, but because the amp was a killer, the sound still banged out of it for about 2 days before the thing went dead and I found out that Im not that efficient on weed as I might have thought. tHe fact is that many amps of higher quality have internal secondary fuse regulators and thats what your **** is running off of now.
Old Sep 9, 2011
Balzdpr's Avatar
This is good advise but im sure that amp is "smoked" as thay call it.
Old Sep 10, 2011
lowlife9's Avatar
well if its faulty manufacturing you mite have a small possibility of getting it replaced.
Tedverseti
Apr 23, 2020 01:45 PM
Hutch1051
Sep 29, 2015 09:20 AM
IronFist
Sep 25, 2015 07:13 PM
PunX
Sep 23, 2015 10:45 PM
pilebuck13
Sep 21, 2015 10:45 PM
