LED Thread!
Old Nov 18, 2011
  #241
civicchick2001's Avatar
CivicChick2001
civicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to all
Re: LED Thread!
Heeyy
heyyy sry, i was in ghost mode again. ill try to keep up to date on here. lol
Old Nov 18, 2011
  #242
~Shibikku~'s Avatar
~Shibikku~ is an unknown quantity at this point
Re: LED Thread!
Typically, they should dim out when you close the door, and after 30 sec they will turn off
yea they dim but they dont turn off completely, i drove for about half an hour and they still didnt turn off, just really dim, sorta flickers when i gas....
Originally Posted by gearbox
as for the leds staying on dimly, its just that particular bulb you got. most should not do this at all. the luxer1 bulbs i have turn off completely.
sweet thanks! i'll order another one then
Old Nov 18, 2011
  #243
Running Riot's Avatar
^Warranty voider
Running Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of light
Re: LED Thread!
i know im the odd man out here having a 6th gen and all but it IS an LED thread to so what the hell. Not meaning to thread jack here either
My hatchback didnt come with a trunk light which, I don't have to tell yell is a royal pain in the *****. So I wanted to put one in and I have an infatuation with LEDs so why the hell not put one in?
I snagged a trunk light from an eg hatchback and I ordered a cool white SMD LED on eBay.
I wired the power to the positive terminal on my amplifier since its hot in.
I grounded the light to the trunk release indicator, its the blue with black wire on the passenger side of the car, underneath the rear speaker. In the sixth gen anyway...
popped it in place.
Voila, ill snag a pic tonight.
To civicchick: if you want to hook one up to turn on when you pop your glove box, you will need an interrupter switch, you can get it at RadioShack. It will close the circuit when the glove box is open and open the circuit when the glove box is closed. Youll have to drill a hole between the dash and the glove box lid so that it makes contact with you close it. Does that kind of point you in the right direction?
ID:	82097   Click image for larger version
ID:	82098   Click image for larger version
ID:	82099   Click image for larger version
ID:	82100   Click image for larger version
Old Nov 18, 2011
  #244
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
Re: LED Thread!
if you have a 2002, the piece pulls right out. not sure on other years.
I think they changed it in '03. It's a pain having to take the center console out, wish they would've left that access panel design.
Old Nov 18, 2011
  #245
Re: LED Thread!
nice trunk light install. how did you have the right size hole already there? or was it just covered with a cap for your model.
Old Nov 18, 2011
  #246
^Warranty voider
Re: LED Thread!
^ im sure there was a cap there at one point but when i bought the car it was just a hole. I doubt honda would have left it like that brand new, i think it had popped out and the jack *** retard I bought the car from just left it like that. thankfully the eg hatch uses the same exact housing
Old Nov 18, 2011
  #247
Artificial's Avatar
Artificial has a spectacular aura aboutArtificial has a spectacular aura aboutArtificial has a spectacular aura about
Re: LED Thread!
It's not that complicated.
All you do is remove 3 pieces of plastic and 2 screws to get it out.
Old Nov 20, 2011
  #248
420Coupe's Avatar
420Coupe is an unknown quantity at this point
Re: LED Thread!
Has any one had any problem with Brake Light LED's Melting ?
Putco has sent me 6 replacements already and they have all melted. I will never buy another Putco product again. Each time they said they upgraded me to a better more expensive brighter LED that had more LED's etc. all of them melted.
Old Nov 20, 2011
  #249
Re: LED Thread!
yeah with all the cheap junk out there its entirely possible (or expensive junk if they marked up the price for better profits). many of those bulbs use generic higher power leds that require large heatsinks to function properly. they draw too much power and melt themselves with no place to dissipate all the heat. an easy way to confirm is find a multimeter that can read current up to 10 amps and see what the led is drawing when hooked to 12v power supply. 350mA = 1w and i would not recommend using a bulb that draws more than around 100mA unless it has serious heat sinking or you are only using the led for short durations (20 secs or less). the luxer1 led bulbs i posted a while back here only draw 20mA and are super bright. that is only about 0.05w of power draw which is basically nothing. they are super bright because they use advanced nichia leds with a high lumen/watt ratio and are very efficient. they hardly even get warm with constant use. i have had very good luck with luxer1 white leds and also the jamstrait led bulbs they sell at autozone (usually the brighter hyper ones need to be found online). their hyper amber 194 led with four 5mm leds on it only draws 40mA and runs fairly cool yet bright.
Old Nov 20, 2011
  #250
sl33pyriceboi's Avatar
Re: LED Thread!
^ur calculations are a lil off.
the equation is Watt = Volt x Amp
W = 12v x .350A
W = 4.2watts
1w = 12v x A
1w/12v = .083A
= 83mA (for 1w)
Old Nov 20, 2011
  #251
Re: LED Thread!
double post FTL
Old Nov 20, 2011
  #252
Re: LED Thread!
there is no calculation tho, these are actual measured standards when running hi power leds. 350mA=1w, 700mA=3w, 1000mA=5w etc. 70mA is what standard superflux leds run and they barely even get warm (no heatsinking required). this is nowhere near what 1w would dissipate. i have played with tons of leds and there is no way 83mA=1w. not even remotely close. most oem tails run their superflux leds at close to 80mA and if it were true that it was drawing 1w of power, those leds would burn out in a matter of hours from thermal failure. 1w produces a lot of heat. i think there is something both of us are missing and im gonna ask the led guys about it later. i dont know enough of the math details to say either way, im just going off of experience and measurements.
Old Nov 20, 2011
  #253
Re: LED Thread!
okay this is correct. seems we were thinking about two different things. i was talking about power consumed by the led die only, not the entire installed circuit (including resistors or drivers). the equation below is for everything together led and resistor. since the post above me was asking why his bulbs were melting, i assumed leds were running too hot and drawing more current than they should be. in most cases, the resistors should be dissipating most of the heat and making sure the leds only get what they need to run efficiently. sorry for the confusion. this equation is right when calculating TOTAL wattage draw with everything installed on the car.
W = 12v x .350A
W = 4.2watts
1w = 12v x A
1w/12v = .083A
= 83mA (for 1w)
Old Nov 21, 2011
  #254
Re: LED Thread!
OHHHHHH ok.
you were talking about the actual voltage of the LEDs.
most LEDs require 3v-4.2v to opperate. anything more will fry them. thats why we have drivers/resistors/PWMs to power the LEDS
so gearbox, you are correct...
if the LED requires 3v (and most do) 350mA*3v = 1A (about 1.05A)
Old Nov 21, 2011
  #255
Artificial's Avatar
Re: LED Thread!
Resistors should be coming today, LED strips tomorrow or Wednesday.
Thinking about buying my speakers before Black Friday and Cyber Monday.
Old Nov 22, 2011
  #256
ibanez6686's Avatar
ibanez6686 is an unknown quantity at this point
Re: LED Thread!
Been a while since I've posted on here. Been kind of busy, but I finally found a few minutes to get some pics of all my LED's!!! Here we go..
License Plate Lights (Just a tad bit more dim in real life)
Plate Lights and Reverse Lights to show the differene
Just Reverse Lights
Reverse Lights at an angle
Plate Lights and 6000K HID's (Just thought the two always look nice together)
All interior lights
View from the side
Just the rear
Trunk Light (Got a better picture than the one a few pages back!!)
All under $10
Old Nov 22, 2011
  #257
Artificial's Avatar
Re: LED Thread!
Looks good ibanez. I have all the same lights, minus the HIDs. Do you have projectors?
Got my resistors today. My blue strip LEDs should be here tomorrow. So, I'll be installing my footwell lighting tomorrow night.
Old Nov 22, 2011
  #258
ibanez6686's Avatar
Re: LED Thread!
Thank you!!! Yes they are projectors. The orange glow above the cut off line is from the turn signals, parking lights, and halos.
Old Nov 22, 2011
  #259
Re: LED Thread!
are the park/brake lights led also?
Old Nov 22, 2011
  #260
ibanez6686's Avatar
Re: LED Thread!
No they are not LED's. I am going to swap to the 04/05 tails soon. Debating whether or not I should buy the LED tails, or just buy normal tails and put LED bulbs into them. Or just get the tails and leave normal bulbs in them...
Old Nov 22, 2011
  #261
Re: LED Thread!
yeah definately go for the led tails. they look exactly like the 04-05 honda lights but have a led array for park/brake. way brighter and safer than putting led bulbs in.
Old Nov 23, 2011
  #262
^Warranty voider
Re: LED Thread!
^I got LED bulbs in my EK tails and I haven't killed anyone with them yet lol
Old Nov 23, 2011
  #263
Re: LED Thread!
well people should be watching and paying attention but usually they are busy doing other things and a brighter brake light can only help. ive seen some really dim lights before and could still see enough to know what hes doing, but not everyone pays attention to that stuff. brakes and rear signals are the two most important lights.
Old Nov 23, 2011
  #264
ibanez6686's Avatar
Re: LED Thread!
So if I do the 04/05 conversion will the LED tails be a straight plung and play. I'm just worried about getting those. IMO, one one LED in the array goes bad it just ruins the look. Here they are...
http://www.andysautosport.com/honda/...o00166182.html
Old Nov 23, 2011
  #265
Re: LED Thread!
yeah those. the leds are not the greatest quality, but they are bright. so long as you dont sit on the brakes for minutes at a time, they will last forever. i always let off the brake after stopping so my rotors dont warp, and that saves the bulb life quite a bit too.
Old Nov 23, 2011
  #266
ibanez6686's Avatar
Re: LED Thread!
I'll probably just get the regular ones and maybe put LED's in them down the road. I'm not the only one that drives my car, just most of time. I don't think I will be able to teach the other people that drive it to go into neutral at red lights. What kind of LED bulbs would you suggest that would fit the 04/05 tails. I know most of the bulbs are the same for the 01-03's except for the brake lights.
Old Nov 23, 2011
  #267
Re: LED Thread!
i have jam strait bulbs and like em but they are not as bright as bulbs. i have those in my front park and turn signal, and sidemarkers where brightness isnt as important. but you have to find the hyper bright version which is the best one. ebay usually has em, and autozone has the 194 version. im not sure what size your bulb is in those tails, but im guessing 7440/7443 type. which you dont have many options for. led bulbs are pretty unreliable too and its likely you will burn those up if you use it often. vleds.com has some pretty bright hi power versions but they cost a bundle.
Old Nov 25, 2011
  #268
ibanez6686's Avatar
Re: LED Thread!
Went with the normal tails. Going to stick with the normal bulbs for now. I'll post a pic of the reverse bulbs when I put the new tails in. Should be a lot brighter with the clear lense!!
Old Nov 26, 2011
  #269
^Warranty voider
Re: LED Thread!
i have SMDs in my tails and turn signals and they are bright in the daylight. Very directional to the rear, not so much to the sides....but im more concerned with people rear ending me. Ill snap photos.
Old Dec 4, 2011
  #270
AUTO Design's Avatar
Former Sponsor
AUTO Design is an unknown quantity at this point
Re: LED Thread!
SMD is always better than the regular LED these days. Or get the CREE LED for the reverse light. They are at least 5 times brighter than any SMD LEDs.
