LED Thread!
Re: LED Thread!
i personally like the "smd led's".. they just seem so much brighter. that's the kind that are in the LED strips in my trunk. and they light it up great! i dont know if they are better or not, but i like em..
Re: LED Thread!
SMD is just the type of housing they're in, the little rectangular prisms rather than traditional cylinders. They're a more compact option compared to the traditional shape.
Kenny the Ricer
Re: LED Thread!
It's funny, cos in HS, SMD means... well, think dirty
But anyways, the bulb type LEDs have more light dispersion, but causing the light to have lower output
The SMD's, or Surface mounted diode's are directional and typically brighter, but less light dispersion over an area
Re: LED Thread!
I decided to create my own version of the LED dome lights
They're actually extremely bright i think its 18 LEDs and it lights up my entire car with out the rear dome light on. Im thinking about moving this one the to the rear dome light and putting 3 of these for the front dome light.
http://www.sparkfun.com/products/9637
Re: LED Thread!
So I ordered LED's for my license lights, reverse lights, trunk light, and dome and map lights in the front. All of them are the same bulb type. I ordered these....
http://www.ebay.com/itm/160523747791...84.m1439.l2649
Granted I tried installing them last night at 10. got them into the socket of my license plate lights first. Fits perfectly, SUPER BRIGHT!!! I was feeling on top of the world at that point. Then I went to put them back where the bulb goes and sits in the lense, too big!!!
Has anyone else enountered this problem?!?!?!? Or would it just be best for me to reurn them, get my money back and buy different ones that would fit?
Speaking of which, can someone please share an ebay link with the 194 type bulbs that you bought for your lic/reverse/trunk/map/front dome lights? I would much appreciate it!
Kenny the Ricer
Re: LED Thread!
Just head over to ebay, type in T10 SMD LED
and you get lots that pop up
The biggest you can go for license plate is probably this size
http://cgi.ebay.com/ebaymotors/2-pcs...item1e67433333
But that size wont fit the maplights
Scroll through this thread and look at my LED pictures and you'll see what fits
Kenny the Ricer
Re: LED Thread!
I ordered these bulbs for my license plate ones. I haven't got them yet, but I'll let you know if they fit when I get them. I'd return the one you got.
I have dim bulb type LEDs for license plate, that way the copper wont see my plates a mile away XD
Re: LED Thread!
What about this...
http://cgi.ebay.com/ebaymotors/2x-T1...item1e66bce979
Would these guys fit into all the spots?
Re: LED Thread!
Originally Posted by ibanez6686
What about this...
Kenny the Ricer
Re: LED Thread!
It may be a gamble in the map lights, but for sure it'd fit in the license plates
Anyways, i finally found out what to do with my 31mm festoon LEDs that I had laying around, turns out they fit perfectly in my CR-V
Re: LED Thread!
Posting this again. I'd like to do my footwell lighting and cupholder lights kind of soon.
I'm 99% sure this circuit is wrong. I'd appreciate it if someone could help me out.
Re: LED Thread!
Re: LED Thread!
I also just got my rear dome light in today. I heard somewhere on here that it is a 31mm bulb, I have an 03 EX Coupe btw. Well it came in and to me it looks very small. I tried plugging it into the spot and it is too small.
The lights do turn on when the positive and negative are touching their respective sides, but it is too small to stay in place. Here is a comparison of the stock bulb and the new LED
Was I correct that 31mm is the corret size or was I mistaken? Right now I have the LED in my car being held in by white electrical tape
Re: LED Thread!
Damnit you're right!!!! GAH!!! I need to learn to read things over again! Well time to talk to some more eBay people...
I'm also still looking for bulbs for my front dome lights, trunk light, andplate bulbs. I'm afraid to make the same mistake that I've now made twice!!!!
Re: LED Thread!
Alright after my two failed attempts at buying the right sized bulbs I'm ready to try again, but just want to run these by you guys real quick.
For the front dome/map lights, trunk light, and license plate lights I have come up with these...
http://cgi.ebay.com/ebaymotors/2-x-T...item19c7362cab
For the rear dome light I couldn't determine if it was a 41mm or 42mm bulb so I found one of each. Could anyone tell me which is correct? Here they are..
http://cgi.ebay.com/ebaymotors/2x-42...item20b9a7a4f4
Thank you!
Thank you!
Kenny the Ricer
Re: LED Thread!
Thank you!
Thank you!
Front Map Lights
2x Car 4 SMD LED Parking Wedge Lamp T10 White Light 12V
Rear Dome Light
41mm Power 18 Smd Led White 6413, 6429, 12844, DE440
Have fun
Kenny the Ricer
Re: LED Thread!
You can get more, but you'd have better results with them flat mounted rather than 5 way, since there is nothing reflective inside the license plate light, instead, the plastic shroud actually acts as a diffuser.
something like this would be plenty bright enough
http://cgi.ebay.com/ebaymotors/2X-28...item35b5d805cd
I just have the bulb type LEDs for my license plates, I personally dont like them too bright
you can check it out here:
Look at my plate lights compared to reverse, that's how I like it
Kenny the Ricer
