LED Thread!
Old Dec 4, 2011
  #271
Re: LED Thread!
the cree led is crazy bright for reverse if you actually want to see behind you, just noticed you guys carry those too.
Old Dec 4, 2011
  #272
sl33pyriceboi's Avatar
Re: LED Thread!
Originally Posted by AUTO Design
SMD is always better than the regular LED these days. Or get the CREE LED for the reverse light. They are at least 5 times brighter than any SMD LEDs.
Depends which Cree led u are using. There are Cree LEDs tha produce 10lm and some that produce 1000lm
Old Dec 4, 2011
  #273
Re: LED Thread!
this one has the big boy hi wattage XRE emitter running at 5w (cant use it for anything but reverse light or it will overheat. they have a constant current driver in the bulb base.
Old Dec 5, 2011
  #274
AUTO Design's Avatar
Former Sponsor
AUTO Design is an unknown quantity at this point
Re: LED Thread!
Correct! Its the best aftermarket LED so far on the market! Wish they can use it for headlight, tail light, etc...
Old Dec 5, 2011
  #275
Re: LED Thread!
^the XR-E are old...and which bin are you talkigna bout? R2? R4?
the XP-G and XM-L are the newest leds out there right now.
Old Dec 5, 2011
  #276
blacksun's Avatar
Back Home With Honda
blacksun is an unknown quantity at this point
Re: LED Thread!
I was hoping to swap out my dome light bulb with an LED upgrade, but have hit a snag. After finally getting the clear cover off, without busting anything, I saw that the installed bulb was longer than the replacement I had. Don't know what's going on. The 31mm DE3175 I was sure was correct for my application, but....??? My car is an '05 2 door coupe and there are no map lights just a centre dome with a single bulb. Sylvania suggests DE3175 also, so I have no idea what's going on. Any thoughts or suggestions from someone would be greatly appreciated. How many bulbs can there be for these cars??
Old Dec 5, 2011
  #277
Re: LED Thread!
31mm for 01-05 civic should be correct. 37mm was never used altho i think it may still fit in the slot. 31mm should fit no problem. did you measure the oem bulb? its possible you got sent the wrong led bulb that is shorter than 31mm if it doesnt fit in the housing.
Old Dec 5, 2011
  #278
blacksun's Avatar
Re: LED Thread!
Originally Posted by MarkieMark
i popped off the silver end caps on the stock bulbs and slippped them on the ends of the new one.
This is my problem exactly. Went to swap out the stock bulb for an LED upgrade and the 31mm bulb looks smaller than what I had already in there. Only advice I've had so far is to check the sylvania website, but it says I require the 31mm DE 3175 that I apparently already have and that one just can't be right. Man, I hate when something so simple turns out to be a hassle!
Old Dec 5, 2011
  #279
blacksun's Avatar
Re: LED Thread!
I think you must be right. I haven't measured the bulb, but it sounds like the simple explanation. Hopefully I was just sent the smaller/wrong size and I need to get an actual 31mm one next time around. On the off chance that isn't the case, you're saying there is a 37mm bulb I can find to use? Thanks for the imput, it's appreciated!
Old Dec 5, 2011
  #280
Kennykid2002's Avatar
Kenny the Ricer
Re: LED Thread!
See if your dome looks like mine here:
https://www.civicforums.com/forums/2...ml#post4560027
If it is, Sylvania is wrong, the 31mm are for certain models (I'm not sure which)
that has the 31mm map lights
I had also originally bought the 31mm because of sylvania
If your light looks similar to mine, it could be a 41mm instead.
Old Dec 5, 2011
  #281
Re: LED Thread!
the dome light with a single festoon in it (not the dual map lights) uses the 31mm bulb. the problem is very few pnp leds ive seen look the same as the stock bulb. my luxer1 bulbs were an exact match and i got the 31mm version.
http://www.ebay.com/itm/LUXER1-Hyper...item3f0f1f1fe5
Old Dec 5, 2011
  #282
Kenny the Ricer
Re: LED Thread!
That's not the case for me,
Hence why I said I bought the 31mm for my single festoon bulb
Came out short, measured it, was actually 31mm, measured OEM bulb, 41mm
Bought the 41mm, and fits snug in it's spot currently
Old Dec 5, 2011
  #283
Re: LED Thread!
hmm, im not sure how its possible tho, honda only makes one dome assembly like that. do you have pics of what yours looks like inside?
Old Dec 5, 2011
  #284
Kenny the Ricer
Re: LED Thread!
^ Like my last link i posted
I'll get another picture up with a measure for ya
But this was my Ebay purchase (41mm Power 18 Smd Led Festoon Bulb 211 569 578 211-2)
EDIT: Keep in mind, this is the rear dome
Old Dec 5, 2011
  #285
Re: LED Thread!
yeah the festoon dome light with a single bulb in it.
i just looked it up, and the dome assembly is the same for all 01-05 civics. the dx has just the festoon assembly, the ex has the festoon assembly for the rear dome, and the lx has the front festoon map lights. all the festoon bulbs listed by honda are the same size. and the light assembly is the same part number too. the bulb is called T-3 by honda, and when i picked up a spare at the dealer, it was a 31mm festoon bulb like what is listed on the sylvania site. im not sure if a larger festoon bulb could fit but its possible, and maybe the previous owner used the wrong bulb. i guess it doesnt matter so long as the bulb can be installed in the metal clamps.
#1 dx festoon lamp part# 34250-S5P-A01ZA
#1 ex festoon lamp assembly part #34250-S5P-A01ZA
#12 lx front map light assembly
Old Dec 5, 2011
  #286
Kenny the Ricer
Re: LED Thread!
hmmm, seeing that, I def needed to break out the camera and measure
This is the what I have in right now, the 41mm LED that fits snugly into place
And this is a comparison of the bulbs
Taking out the OEM civic rear festoon, i could see it reading T-3 578
Quick google of 578 bulb comes out to be a 42mm festoon
I'm confused as well
Old Dec 6, 2011
  #287
Re: LED Thread!
wow interesting. your insides look completely different and i think actually its the color of the housing! tomorrow i will snap a pic of my "grey" version lol so you can see the smaller bulb. looks like honda made a mistake with the bulb sizes. the housings have different part numbers but that is ofcourse due to them having different colors. grey housing = 31mm, brown housing = 41mm lol i never wouldve imagined because the shapes are so similar.
Old Dec 6, 2011
  #288
Kenny the Ricer
Re: LED Thread!
Well, I have a beige interior, and the housing is beige as well...
Don't think it really makes a difference
Did you check the difference between 01-03 and 04/05?
Old Dec 6, 2011
  #289
mac25's Avatar
Dr Krieger of Modification
Re: LED Thread!
i had neon tubes two under the drivers side and passangers and wo in the back that beat to my house music...then i pulled someone over. that's how i found out you could see them form outside. so now they're in my engine. this pic's old but i'll put it up in here anyway.
Old Dec 6, 2011
  #290
Re: LED Thread!
yup 01-05 all use the same assembly and same bulb for the single festoon dome light according to honda. im really thinking its the color making a difference. i've only seen the grey versions and they always used 31mm festoon. this is the first time seeing the beige version.
Old Dec 8, 2011
  #291
Shine.'s Avatar
Shine. is an unknown quantity at this point
Re: LED Thread!
Hey guys I threw some leds in for my reverse light earlier today,i love them!
I was wondering your opinion on these types of leds for my ,map,trunk and license plate
http://www.ebay.ca/itm/10pcs-New-T10...#ht_2585wt_936
Old Dec 8, 2011
  #292
Kenny the Ricer
Re: LED Thread!
10 pc for $6 is not bad
They usually go for $1 a pair, so it's alright
The more SMD's the brighter it should be though
Old Dec 8, 2011
  #293
Shine.'s Avatar
Re: LED Thread!
Yeah I ordered them! Cant go wrong for $6 right
Old Dec 14, 2011
  #294
ibanez6686's Avatar
ibanez6686 is an unknown quantity at this point
Re: LED Thread!
I recently did the conversion to 04/05 tails!! Very satisfied with the result! Thought I would show the difference in the reverse lights from the new tail lights to the old.
For those who don't know these are what the stock 01-03 coupe tail lights look like. (Notice the not clear reverse light lense..)
And here is what the reverse LED looked like inside of those tail lights..
Again, for those who don't know what the 04/05 tail lights look like, I know most of you do, here they are (Notice the clear reverse light lense, makes a HUGE difference!!)
Now the new tail lights with LED reverse lights (A little too much light for my camera, even after I made some adjustment)
I'm loving all of my LED's! I have gotten a lot of compliments on them already! Definitely worth the less than $10!
Old Dec 14, 2011
  #295
MarkieMark's Avatar
MarkieMark will become famous soon enough
Re: LED Thread!
i def. see a noticeable difference!
where did you purchase your reverse leds from?
i'll probably be going with 04-05 tails if the price is right.
Old Dec 14, 2011
  #296
Re: LED Thread!
if you want some lightly damaged one (corners due to shoddy *** packaging from the dude I bought 'em from), I'll sell 'em cheap.. lol..
https://www.civicforums.com/forums/1...il-lights.html
a heads up for you guys.. v-leds.com has some of their stuff on sale.. up to 50% off, ends tonight. Some of their stuff is pricey though.
Old Dec 14, 2011
  #297
ibanez6686's Avatar
Re: LED Thread!
All of my LED's were just from eBay.
Old Dec 14, 2011
  #298
lazlong's Avatar
Re: LED Thread!
@ xRiCeBoYx: How many amps can the TIP-31 handle?
Old Dec 18, 2011
  #299
lazlong's Avatar
Re: LED Thread!
Never mind. It's 3 amps.
Old Mar 2, 2012
  #300
Fate's Avatar
Fate is an unknown quantity at this point
Re: LED Thread!
pretty sure im LED'ed out
Can you tell me where you got your led's? Or maybe the color, that is exactly the color I was looking for. I really want the whitish/blue, kind of color.
