Wheel Well Splash Shield Removal Question
Old Jun 5, 2008
synod's Avatar
synod is an unknown quantity at this point
Hey guys, I'm installing some m3-style side mirrors with blinkers in them, and I've got a question about removing the plastic well behind my two front tires to get to the wires I need to tap. How do I do it without breaking any of the clips off so that I'm able to put it back on and it won't hang loosely?
Step 2 on the sidemarkers guide just says "pull back the splash shield":
https://www.civicforums.com/forums/1...d-washers.html
however I'm not finding it that easy. I feel like I'm going to break the clips that are holding it onto the fender. Is there some way to remove the clips or should I really just give it a yank? I've removed almost the entirety of my car's dash and inside door panels, but I've never done anything on the exterior and I don't want my wheel well to hang down, rub my tire, and look like crap when I'm done.
2004 Civic LX Coupe. Rallye Red, because it matters.
Thanks in advance for the advice.
Old Jun 5, 2008
sicma99ot's Avatar
just a man with a civic
sicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of light
Re: Wheel Well Splash Shield Removal Question
no dont yank on them. lol
im not too sure how to explain this, but the clips should either screw out or pop off. under your hood, there is, to my knowledge the same clips that hold the bumper and grille on it.
Old Jun 5, 2008
Unevolved's Avatar
Rough, Tough, Real Stuff.
Unevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to behold
OK, I don't have a picture of what I'm about to explain, but bear with me. There should be either a screw head or two flat spots to the side of a circular center piece. If its a screw head, unscrew it. If there's two flat spots, use two small flat-head screwdrivers to pry up the "core" of the clip, and the outer part will come out easily then.
Sometimes they get worn out and hard, and there's nothing you can do but fight them. Hope this helps.
Old Jun 5, 2008
sicma99ot's Avatar
this should be a DIY lmao
Old Jun 5, 2008
use a flat head screwdriver to pry out the middle of the clip, then the outer piece will come out.
Old Jun 5, 2008
CraigW's Avatar
I saw replacements available at the auto parts store recently.
They break easily.
Old Jun 5, 2008
Jza's Avatar
Jza
Jza is a jewel in the roughJza is a jewel in the roughJza is a jewel in the roughJza is a jewel in the rough
if you break the clips, can't you use zip ties like everything else?
Old Jun 5, 2008
Unevolved's Avatar
Not usually, it just won't work in this situation. You'd have to cut a chunk out of the splash guard.
Old Jun 5, 2008
synod's Avatar
That's what I tried to do earlier, I was just afraid that they were going to break due to the amount of force I was using. My car is in the shop having body work done (visiting home for the weekend and my mother backed into my drivers side door and kept going ), I pick it up tomorrow and I'll get on this and let you guys know if I destroy anything. Thanks for all the help. I'll bring my camera along and take some pictures and try to throw together a DIY if it goes well.
Old Jun 5, 2008
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
you can get a tool for this, i have all kinds of panel popping tools.
Old Jun 6, 2008
TRIZ's Avatar
Oh man, the posts in this thread are confusing and wrong. Listen to gearbox- thats exactly how to remove the clips inside the splash guard. You only need one screwdriver. Just be careful and take your time. Replacement clips can be had @ homedepot, lowes, honda, and most automotive shops if you break them.
Old Jun 6, 2008
emjay's Avatar
emjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the rough
does anyone know where u can buy the splash shield from ?? i need the driver side
Old Jun 6, 2008
EXsmellsbetter's Avatar
Mr. Treehorn treats objects like women, man!
EXsmellsbetter has a spectacular aura aboutEXsmellsbetter has a spectacular aura aboutEXsmellsbetter has a spectacular aura about
Heck yes! I always get my parts from the guys at hondaautomotiveparts.com They are good stuff. And the only thing better than using a flathead screwdriver to pry those guys out is using two flathead screwdrivers and just gently twisting them from side to side as the middle part slowly comes out. Then the outer part practically falls out without the middle. Those things are like a buck fifty apiece so be careful! lol
Old Jun 8, 2008
qijian's Avatar
yeahh does anyone know where we can get one? i neeed one for the 05
Old Jun 8, 2008
TRIZ's Avatar
Majestic: http://www.hondaautomotiveparts.com/...artsSearch.jsp
GolNat
Suspension DIY
May 12, 2022 06:49 AM
BootyDo
May 8, 2015 05:36 PM
nontypical
May 4, 2015 04:10 PM
bsmiley
Apr 27, 2015 01:27 PM
Civic4ever1996
Apr 16, 2015 08:30 PM
