headlight switch
headlight switch
i no i read this somewhere but i did a search 4 like a hour and couldent find it... right now i have neons connected to my fuse pannel. i like to have it so when i turn on my head lights they turn on. i know this can be done useing a relay but i dont no which wires to tap into or which go where on the relay is there a guide around here someone can link me to or can comeone walk me threw it thanks
pin 86 - input from parking light wire or whatever wire you want to use to trigger the relay
pin 30 - +12 volts ignition - fuse this line, 3 amps should be fine
pin 85 - ground
pin 87 - to neons
I believe that is right, if I am wrong somebody correct me
pin 85 - ground
pin 87 - to neons
easyest way is drilling hole.....run it to park lights....
if u dont want to do that.......i am sure park wire should be under the stering....but i dont know about the colors.......
check the alarm wiring diagram on this site. itll tell you wire color and where in the underdash to find it. youll grab the headlight wire and use that to peg the relay. no drilling required, and no firewall to deal with.
every single light in your dash is hooked up to the headlight switch.
ok so i looked on the chart and i need the PARKING LIGHTS + red/black wire correct? and it says location back of the fusebox so do i have to remove the fuse box to get to it or just remove that brass screw on the bottom
yep, sounds about right. you shouldnt have to pull the fusebox though, the wire is running around.
like I said, you can even find it attached to your gauge cluster, to ever device in your center console, etc. its still red/black.
but fish around your underdash, itll be there accessible somewhere.
allright so i did this today and i have the 12v connection conected the the fuse panel and with a 3 amp fuse it all works but when i turn on the lights theres a clicking noise under the wheel i was wondering if this was just the normal light sound when they go on or if it something with the relay or fuse connection
Picture worths a thousand words!!! Hook the "2" and "3" up through a relay to your neon lights (don't worry about the "1", I circle it for something else). They should lit up only when the parking lights are on. This is actually the factory setup for the aftermarket foglights. So, there is no stripping, no parting at all. Just get 2 new plugs and you get the power whne the parking lights are on.
jessica19699
Jul 29, 2015 05:51 AM
