Sponsored by:
Sponsored by: CARiD
CAI and hydrolock
Old Feb 13, 2005
bgoetz's Avatar
bgoetz is an unknown quantity at this point
CAI and hydrolock
Ok I know that this has been discussed a billion times, but everytime it seems to get way off topic. I have one simple question I am changing my SRI for a CAI. Do I need to be concerned hydrolock??? I know that if I drive through standing water and the filter is submerged then I do. However what about water that is from the road splashing up and hitting the filter my car sits very low. I also know that a bypass valve will not help in this situation that is why I am concered. Do I need to be???
Lets just keep this thread about this question only there are enough threads debaiting the two I have already made my decision I just need to know how careful I need to be.
Old Feb 13, 2005
hotrodcivic2004's Avatar
my civic has no boost
yes u do.
Old Feb 13, 2005
tonyt915's Avatar
tonyt915 can only hope to improve
i never had any problems with mine in water and i didnt have the bypass, also i hydroplaned in a large amount of water and it did not suck up any
Old Feb 13, 2005
Mirage's Avatar
Mirage is an unknown quantity at this point
No, you dont have to worry about it. We have sprayed water (at full blast) directly onto the filter element while the engine is running with no ill effect.
To hydrolock an engine, you need to ingest more than 10% water (by volume) into your engine. Think about how much water that is. It simply can't happen without submerging essentially all of the filter under water. It's like trying to suck the last bit of coke out of the bottom of a cup, once you get any air, you stop getting fluid.
Now, if you do submerge the filter 100% under water while the engine is running, you will hydrolock your motor almost instantly if you dont have a bypass valve installed.
Old Feb 13, 2005
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
w3rd you only need to worry about it if the whole filter is submerged and that is the ONLY time that a bypass valve comes into play....
Old May 31, 2005
StealthPilot's Avatar
StealthPilot is an unknown quantity at this point
i have a cold air and i have hydrolocked many times. i also cannot rev the engine in a mild rain without it stalling or sputtering. i wouldn't reccomend it unless your serious about the slight performance gain.
Old May 31, 2005
2K1Civic17"Gabe's Avatar
keep your sri. I never sucked water up in mine, but I live in az and we get like 360 days of sun a year. I dont have it anymore. I took it off for my stock airbox, noticed a nice gain in all rpms, than switched that out for a sri right before I turbod. Than I sold the SRI. I have a very nice gain with my new intake, probably like 1-120 hp at 10psi. haha.
Old May 31, 2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
Ask my friend with the hole out the front of his block!
AngeloS
Jul 16, 2015 11:00 PM
Reginator
Jun 17, 2015 07:54 PM
spoiledsteph
Jan 4, 2002 04:36 AM
se7en
Nov 12, 2001 10:13 AM
Daniel420
Nov 9, 2001 08:36 PM
