06 Civic EX Not Starting - Any Suggestions
Old Apr 13, 2015
SSMatey's Avatar
SSMatey is an unknown quantity at this point
Question 06 Civic EX Not Starting - Any Suggestions
My '06 Civic Ex is not starting.
Basically, I put the key in. The lights and dash powered-on as normal. Turned the key to start and everything suddenly powered off. Tried 2-3 more times and by the 3rd or 4th attempt the lights and dash did not power on.
This happened the first time a month ago. Waited a week, then took the battery to my auto parts store to make sure it was not the culprit. They said it was fine. I left the battery out of the car for about 2 weeks. Decided to have the car towed. Tow truck driver reinstalled the battery and the car turned-on like nothing happened.
One week later it suddenly won't start again. I receive no electrical power at all... the horn won't blow... the doors have to be manually locked/unlocked. I haven't checked any fuses because I don't know which ones to check...
The lights are normal - not dim.
The battery has 80% charge (per my auto parts store).
Did not start with a jump.
Makes no unusual noises when attempting to start it.
Starter replaced last year.
*Weird thing I noticed - 1) The first time this happened stock cd player display did not light up, but started making noise like it was just spinning over and over again. 2) After the battery was reinstalled... the cd player display still did not light up and just made the same weird noise when I pressed any of it's control buttons.
Old Apr 13, 2015
GolNat's Avatar
Prelude Owner
Re: 06 Civic EX Not Starting - Any Suggestions
Sounds like you have an electrical connection that rattles it self loose on you.
Are the battery terminals tight? Chassis ground wire tight? Alternator connections tight? The main power to your fuse box tight? The starter connections?
Old Apr 13, 2015
Originally Posted by SSMatey
My '06 Civic Ex
If the battery, cables and cable ends are really making good contact and not dropping out, I bet you have a
Bad ground connection where the neg cable attaches to the body:
Disassemble, clean everything with a wire brush or sandpaper until there is clean shiny metal on all contact points (bolt, cable eyelet, and body), then cover liberally with dielectric silicone grease to protect it all.
HTH
Old Apr 13, 2015
SSMatey's Avatar
Golnat - yeah it seems like that... but I don't understand how it suddenly rattled itself tight again when no one touched the car. It's kinda baffling. I'm going to look at your suggestions though.
Ezone - I looked at the ground from the from the battery... it seemed a little rusty, but still tight. I'll disconnect, clean, and lube it as you suggested. Is the other cable pictured (top cable that's bolted on the side) grounding the engine?
I'm pretty handy, if I have pictures or diagrams to find the items you guys have mentioned.
Old Apr 13, 2015
Correct. It attaches to the body and trans.
Jonnie.
Jan 13, 2019 11:21 AM
ghondavic
Transmission
Apr 12, 2017 09:37 PM
GaryFishell
Apr 24, 2015 06:49 PM
CivicVoz
Apr 16, 2015 08:07 PM
gabrown2
Apr 11, 2015 08:22 PM
