cigarette lighter issues
Old Nov 13, 2013
tnher1's Avatar
tnher1 is an unknown quantity at this point
The yellow wire came off the connector. The end pieces of that wire are still stuck inside the connector. I tried to force it in, to no avail. Is there a way to take out the broken wires off from the connector? It seems the wire is about 18-20 gauge. I've been trying to get it back to work but now the black wire broke off too. Any suggestions? Thank you!
Old Nov 13, 2013
GolNat's Avatar
Prelude Owner
Re: cigarette lighter issues
The pins in the connector should have a locking tab that you need to push in or out to release the pins. Once out they will need to be crimped again. If you don't have a set of crimpers for that type of pin or a new pin you can crimp new spade style connectors on the wires (if you have the correct spade terminal) to fit the back of the 12v outlet.
4 banger
Jun 5, 2015 01:44 AM
Neofusion
Mar 19, 2002 09:43 PM
RRCivic01
Mar 15, 2002 06:02 AM
Importracer
Feb 7, 2002 07:22 AM
CiViCPrAnInG2k1
Nov 27, 2001 12:07 PM
