problems with painting trim pieces
Old Feb 9, 2002
RRCivic01's Avatar
RRCivic01 is an unknown quantity at this point
Well i wasn't sure if this was a tech question or not, but i'm not really installing anything so... meanwhile for those you who always reply with "do a search" i did one. i couldn't find any info. and yes, i know it's in the DIY but i'm having problems. just so that is clear, here goes.
i'm trying to paint the trim piece on the front console, and this is what the DIY says:
"Remove the center piece by first removing the heating and cooling ***** (just grab and pull), and remove the accessory plug trim piece (looks like a cigarette lighter plug). You will need to put a thin rag on a flat tip screw driver to get that trim piece off. Unplug the plug. Now, if you look up in there, you will see two 8 mm bolts(silver), remove these, then push the bracket up until the center piece pops out. You will have to push hard, but it will push out, the radio and everything is connected to it.( do not attempt to pry this piece out with the rag and screw driver, it will warp the plastic and will not have a good fit when replaced! Trust me ...I know "
ok, i got the ***** off... the accesory plug trim piece, do they mean the actual black piece around the plug or that whole lower console section? i couldn't get either part off... my friend says you have to take off the whole console to take that part off. is that what you do? because we were having trouble with that too. but if you don't have to take the whole console off, my friend owes me a buck. keep that in mind[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 9, 2002
viper775's Avatar
viper775 is an unknown quantity at this point
[IMG]i/expressions/face-icon-small-disgusted.gif[/IMG] lLauren
Old Feb 9, 2002
Voiceofid's Avatar
End Bringer
u have to use a little muscle, a few clips will break off too and u do have to take the center conole off, refer to the diy for stock HU removal for how to take the trim off
Old Feb 9, 2002
viper775's Avatar
And the winner is Shane[IMG]i/expressions/laugh2.gif[/IMG] so go Lauren [IMG]i/expressions/moon.gif[/IMG]
Old Feb 9, 2002
RRCivic01's Avatar
shane, don't give me that lauren crap, you aren't getting a buck!!!
meanwhile, thanks for trying to help but i had instructions on removing the center console and i had problems with that too. if someone has done this do you think you could try and give a few more details than the DIY? please, i beg you!viper755 or 577 or whatever his name is couldn't help me either, right shane??? haha
on another note, what is this face? the curious nija?
Old Feb 9, 2002
viper775's Avatar
Lauren nothing but an
Old Feb 9, 2002
RRCivic01's Avatar
shane: i hate you.
Old Mar 15, 2002
Malfunction's Avatar
Malfunction is an unknown quantity at this point
Yeh you have to take off the entire bottom cigarette lighter dash thing. Just grab both sides and pull, i have had to take this part off so many times that it only has one of those stupid clip things left. Anyway once you have that off, you should be able to see two bolts. Just take those off and push the top plate (you will see two) towards you, and after a little muscle, it should pop right off. Good luck
KronikScott
Jun 9, 2015 08:00 PM
drhawkinz
May 16, 2015 11:39 AM
BabyLX
Nov 8, 2001 09:25 AM
vistec
Nov 7, 2001 05:53 PM
CivicHX01
Nov 2, 2001 08:49 PM
