1999 Civic brake lights not working
Old May 6, 2009
rjannun1's Avatar
rjannun1 is an unknown quantity at this point
I've checked the obvious fuses etc. I changed the brake switch, there is power at the switch but not at the lights.
Any ideas of anything else to check?
Old May 7, 2009
CraigW's Avatar
Re: 1999 Civic brake lights not working
Do you have voltage after the switch ?? (you should)
Does your horn work ??
If no fuses are open and horn works... it sounds like an open connection.
If so, you will need to follow that lead back to the trunk or tap in and run another wire back and tie into the brake light wiring in the rear.
Old May 7, 2009
rjannun1's Avatar
Thanks Craig. The horn does work so I will try running a line
Thx again
CarStuff
Dec 6, 2020 12:52 PM
usajags84
15
Aug 19, 2015 03:12 AM
usajags84
May 10, 2015 08:11 AM
McD
Apr 29, 2015 03:50 PM
bsmiley
Apr 27, 2015 01:27 PM
