is the battery cap necessary?
Old Mar 20, 2008
yingjai's Avatar
yingjai is an unknown quantity at this point
I have an Optima Yellowtop 50R; R means reversed terminals. The wiring harness is not long enough so I had to flip the battery around, but that meant the positive terminal cap must be removed to be able to close the hood. Also, the hood "kickstand" thing cannot be secured using the clip because there isn't enough space. I have been driving for over half a year like this with no problems.
I have time to rethink now because my battery died (music while engine off) and I'm still choosing the charger. Is this a bad idea driving around like this and that I was just lucky so far? My friend warned me that there was a very small chance of the circuit completing from contact with the hood or water splashing. I have no grill as of yet because my car came without one (used). I bought the 50R in a rush and kinda regret it ever since.
Old Mar 20, 2008
CraigW's Avatar
Re: is the battery cap necessary?
If your hood is that close you should have + terminal covered by some method IMO.
Old Mar 20, 2008
yingjai's Avatar
dunno what to do with my battery. i got it for $50 when it was slightly used. still have a lot of life left. dont think many ppl want reversed version.
Old Mar 20, 2008
CraigW's Avatar
You may be fine, but one incident could cause a lot of damage. You could try a square of rubber attached to the underside of hood above the + terminal.
Old Mar 21, 2008
ArrizX's Avatar
ArrizX is an unknown quantity at this point
definitely cover it with something, anything just so it does not contact any other metal. **** cover it with paper and a rubber band, just don't let it start a new circuit.
Old Mar 21, 2008
yingjai's Avatar
im thinking about replacing the battery with a regular size 51 so i can put the cap back on. what battery should i get? odessey?
Old Mar 21, 2008
ArrizX's Avatar
Depends.
Got stock car, or are you running anything after market. i.e. sound system?
Old Mar 21, 2008
electric130's Avatar
i've been running the stock battery for 6 years now with no problem.
Old Mar 21, 2008
speedfoos's Avatar
Or if you want to keep the battery, just put it in the trunk.
Old Mar 21, 2008
yingjai's Avatar
i have a 10" sub, alpine deck, and low end speakers.
would there be less chance of corrosion if i put it in those containers and stuff it in the trunk? so much work to tear my car apart again to do the wiring.
Old Mar 21, 2008
speedfoos's Avatar
Not really much work at all especially if you already have a nice 4 gauge wire running to the amp in the trunk.
That now becomes your battery wire. Cut the terminal off the current pos wire in the engine bay, connect your amp wire to that. Disconnect that wire from the amp and splice it back into the terminal you just cut off. Now all you have to do is ground the battery in the trunk and run a wire from the battery to the amp. Done and done.
Old Mar 21, 2008
yingjai's Avatar
i think i rather keep the battery in the engine bay.
1. it's going to take up more room in the trunk.. not like the sub hasn't taken enough
2. don't really want to cut the wiring harness up
SimpleUser
Apr 24, 2021 02:54 AM
TheRubixHorse
Jul 29, 2015 05:22 AM
jzhartman
22
Jul 23, 2015 10:42 PM
Smokahontas123
Jul 22, 2015 10:07 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
