1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Blower making noise
Old 03-09-2014
jajaja's Avatar
jajaja is an unknown quantity at this point
Blower making noise
Hello,
My ac/heating blower has been making noise for a few months; it sounded like something was stuck inside, so I usually just put the fan up to 4 to blow it loose, and that worked. A few months ago I even pulled a piece of styrofoam out of one of the vents.
Last week, the bottom two fan speeds stopped working. So I diagnosed a broken blower resistor and replaced that today.
Well now, the lower speeds work again, but the blower is making horrible noises and screeching at all speeds.
Do you think something is stuck in the blower? Is that possible?
ETA: I took out the blower motor, and it had a few leaves inside, so I took them out and plugged it back in. It still squeals.
But the motor looks fine from the outside. Should I open it up?
jajaja is offline
Old 03-09-2014
Re: Blower making noise
If it squeals, the motor probably needs replaced.
Unless you think you can take it apart and lube the bearings somehow.
ezone is offline
Old 03-09-2014
jajaja's Avatar
Ah, thanks.
Further on that topic, do you think the blown motor is what made the resistor blow, or is it just coincidence that both happened at the same time.
jajaja is offline
Old 03-09-2014
Probably coincidence, or maybe not.
It's an OLD car, things go bad and break. It's the natural cycle.
ezone is offline
Old 03-10-2014
jajaja's Avatar
Cool.
Should I vacuum out the ducts before I put the new one in? Can I stick a vacuum up the hole where the motor goes?
Or take out a vent and stick it in there?
jajaja is offline
Old 03-10-2014
CraigW's Avatar
When my 05 fan got noisy I drilled a 1/4" hole the plastic cone to access the top bearing to lube (tri-flow) it would work for a short time and the noise would soon return.
CraigW is offline
JAMorganIII
23
07-04-2015 11:52 AM
Bradel26
05-30-2015 10:24 AM
DouglasTheGreat
05-27-2015 11:23 PM
dosmastr
05-05-2015 12:19 PM
SSMatey
04-13-2015 06:09 PM
Quick Reply: Blower making noise
