Car won't rev past 3k or so....D16y7
Rep Power: 0 Car won't rev past 3k or so....D16y7
Ok guys so I changed my head gasket last night got everything done waited till this morning to take her for a spin and it won't barley do 40mph..or past 3k.....fires up fine idles fine...hot heat cold air,full of oil, brand new distributor plugs wires fill of high test gas .....it ran fine before just lost water due to the head gasket ,reason I changed it...checked timing 10 times it's dead on....alsp no cel light....i dunno wth i did wrong....any suggestions? Or ideas
Received 1,456 Likes
Rep Power: 340 Re: Car won't rev past 3k or so....D16y7
Check codes.
Check oil level
Check oil level
trace back the wiring, sensor - are they tight in?
check codes anyway
check codes anyway
Rep Power: 0 Re: Car won't rev past 3k or so....D16y7
Yea sir checked it all, and ran multiple checks with my computer zero codes...at this point im about to remove the crank pully and check the timing mark on the crank see if I got it right. ..i used the farthest line to the right on the pully for my timing...is that right?...also used a screwdriver to check tdc so it should be right but I'm about take pully off anyway
put old distributor back to see if it works?
or some of the new parts? (The easy ones, i mean) there might be faulty ones among the new ones
Yea did that to,got the old one on it now, still starts right up idles fine and revs to 3k..thats it...im about to pull the crank pully...see if I'm in timing, next thing I can think of is the ecu may have went bad?
well my impact won't take the crank bolt off..ugh...so I'm purty sure I have it in timing anyway....i used the mark that over by itself not the 3 that are together. .is that correct? Also that mark is where it landed when I used a screwdriver in the plug hole to find tdc...man I'm stumped on this thing ,still won't pass 3k
Ow... I am running dry on suggestions...
so I've been googling everything I can think of and i think it may be the crankshaft tdc position sensor, this is gona be my next step even though i don't have any codes...this may just be it , fingers crossed ima pick one up tomro after work along with a borrowed impact gun that will remove the darn crank bolt. Sigh
well I decided to check the voltage at the plug to the cps and with the key on testing the harness sideI'm only getting. .4 volts...that can t be right...right?. Also I do have resistance on the sensor itself so it's good or should be...someone know what or why I'm not getting 12v..?
So that was a no go..still only revs 3k or so ,i did notice on my computer it's only advancing the timing like 3degree or so when i floor it....whats up with that?
maybe some wires are pinched and leaking electric power?
I've searched the whole engine bay, nothing pinched or unhooked as far as I can tell,I do and have worked on cars my whole life and haven't run into this problem lol,I'm about to take it to a local shop,after I change the crank sensor for the.hell of it and see what happens, just can t get the bolt loose yet ugh
Also put some new plugs in it , they turned soot black after just idling and reving it for a lil,and white smoke seems to come out the exhaust to when I rev it
did your O2 sensor get soaked in something during the work? that would make it do weird things
No sir I removed the manifold and down pipe first thing set it to the side, ima try post a vid of it,..but it sounds like a 2step almost lol , I think it's def cuting fire to it cause brand new plugs turn black after I run it for a few min, so it's getting fuel for sure ,i been messing with it for a few days and just can't seem to find **** wrong that I may have done anyway
Ok guys so I fixed it.!!!!! So after a month of working on my car and about $600 bucks I have finally fix the somgun.!!!!It was the damn catalytic converter smh...i can't believe it took me soooo long to figure it out but oh well I ain't mad,learned alot from this experience lol
ooooouch!
glad you found the problem, tho!
Tyler1994
03-18-2016 10:21 PM
Greenmonster
11-09-2014 07:57 PM
Dustin19902
08-10-2014 08:00 PM
Blkcivic787
03-30-2014 02:45 PM
hoppy
08-31-2012 03:28 PM
