Unable to remove egr valve
Old Dec 20, 2017
Marquez760's Avatar
Marquez760 is an unknown quantity at this point
Hey guys so I’ve been having stalling and hesitation on acceleration issues with my civic and I have a p0404 code when my engine light comes on so I took my car to my mechanic hoping he would be able to remove it and it was unsuccessful. One of the nuts wont come off and it looks molded on also it looks as if someone banged on it with a hammer before. I was thinking about trying a egr cleaner spray since I can use it without Removing the egr valve but I’m not sure how effective that will be.
Old Dec 20, 2017
Wankenstein's Avatar
Re: Unable to remove egr valve
Try spraying penetrating lube spray on it such as PB Blaster and leave it on for an hour or so before trying to remove nuts.
Other methods:
Butyl torch to heat (expand) nut. Not sure if using heat in that particular is safe to do..doesn't seem safe anyway..lol
Rotary tool (Dremel) and cut almost through nut in two places and then use a chisel to pop the nut apart without damaging the stud's threads.
and this:
Here's another possibility:
all-lude
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Mar 18, 2023 07:37 PM
Dretoven
Feb 9, 2018 01:58 PM
maverickfhs
Jan 1, 2017 12:21 AM
V8KiLLA
Mar 28, 2002 12:24 AM
