Help With Camber Kit for my em2
Re: Help With Camber Kit for my em2
Definite yes on the cam bolts but they might not be enough if your gonna drop it 3 inches you still might get some tire lean.. im at 2 inches and the cam bolts barely corrected the lean.
http://www.summitracing.com/parts/sp...02/submodel/ex
Im just guessing you have either an 01-02.. civic and yes you need them
02 uses 14mm, if that's the question.
if you use 16mm, you need to drill out the knuckles for them to fit.
3 in and that means your rear camber kit will not be enough to have them close to zero, if memory serves me well, so you need to compensate by increasing the front neg camber?
no, the struts have a hole bigger than the bolts, so you either use the reducing washers or drill out the knuckles and install the larger bolts. search the site for reducer washers and you will understand what I mean.
Your going to need DC5 tie rod ends also. The bushing on the rear struts May also have to be shaved down a couple mm to fit. Don't know if the shop will do that, might want to ask just incase they do.
Dave Brabant
20
Oct 6, 2015 12:44 AM
Hutch1051
Sep 29, 2015 09:20 AM
beanhead
Sep 24, 2015 12:04 PM
