02 lx with 05 struts?
Old Feb 2, 2013
dsfoster63's Avatar
dsfoster63 is an unknown quantity at this point
Hello I have finishe (I thought) a engine and Trans swap fom an 05 to an 02. The struts have diferent sized mounting bolts on the bottom. should I swap the knukles and struts in from the 05 or do I need to stick with all 02 parts on the suspention?
Old Feb 2, 2013
Re: 02 lx with 05 struts?
Really, the only difference is the size of the crash bolt. I've heard of people drilling it out from 14mm to 16mm.
Old Feb 2, 2013
lowlife9's Avatar
yup you need to have the holes drilled to 16mm.
Old Feb 3, 2013
or use reducing washers
see previous one asking same stuff:
https://www.civicforums.com/forums/4...vic-coupe.html
link posted there does not work anymore, but just type washer in ksport site search and it should show the reducer washer.
Old Feb 4, 2013
sl33pyriceboi's Avatar
the 05 has 16mm clash bolts.
the 02 uses 14mm.
therefore, you need REDUCING washers.
Old Feb 4, 2013
also, in terms of STOCK struts, the 01-02 uses a 50mm strut housing and the 03-05 uses a 55mm strut housing. bitter strut, better built.
Tedverseti
Apr 23, 2020 01:45 PM
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
Wariogamer
Sep 29, 2015 09:49 AM
