Clearance issues?
Old Feb 3, 2013
BlooEM2's Avatar
BlooEM2 is an unknown quantity at this point
Lightbulb Clearance issues?
ive got a couple different questions, first of all anyone have any opinions on raceland coilovers?
Second with a thick rear sway bar and coilover setup does anyone run into any clearance problems with the exhaust? Ive got a cat back and i plan on getting coilovers and a thicker bar and wanted to make sure nothing would hit or touch and that i had enough room.
input is greatly appreciated!!!!
also its a 02 ex coupe if that makes any difference
Old Feb 4, 2013
BlueEM2's Avatar
Whachya lookin at?
Re: Clearance issues?
Raceland coilovers are a no go. Progress is probably the best budget coilovers for our car. They are still however around 1100 dollars.
You should be okay for clearance. Many have run thick sways with coilovers without any issues
Nice name BTW !
Old Feb 4, 2013
my progress did hit the stock exhaust, some of the thicker ones might hit too
Old Feb 4, 2013
krudmuphin's Avatar
I have a 21mm sway bar, 2.5" exhaust, and lowered about 1.5" and yes, there is contact between the sway bar and the exhaust. I made a simple solution of cutting a round foam tube to put over the sway bar to prevent rattling.
Old Feb 4, 2013
TFMEX's Avatar
CO&CA
TFMEX is a jewel in the roughTFMEX is a jewel in the roughTFMEX is a jewel in the rough
You can always bend the exhaust hangars to create clearance. That's what i did and it works great.
Old Feb 4, 2013
lowlife9's Avatar
in for when krudmuphin smells something burning.
Old Feb 4, 2013
BlooEM2's Avatar
what exactly makes the raceland coilovers a no go? ive read good reviews on them...not specifically for my car but on others... just looking for some insight, thanks. and at what height does teh clearance become an issue. i want it dropped like an inch and a half.
Old Feb 4, 2013
krudmuphin's Avatar
If anything's gonna burn on my car, it'll involve my crappy wiring skills. The foam I used is dense and made to withstand heat (not that your exhaust is extremely hot at that point of the system anyway)
Now, Raceland coilovers lack Quality Control. So basically that means you're buying a product where each item isn't tested before selling it. To sell at a lower price, they are made with lower quality materials which have a much less consistent success rate. The chances of getting Racelands that will fail (mildly or catastrophically) is greater. Your life as a driver depends on safety, and suspension is one of the most crucial aspects of the cars performance. You should always buy superior quality suspension parts.
Old Feb 4, 2013
BlooEM2's Avatar
Now, Raceland coilovers lack Quality Control. So basically that means you're buying a product where each item isn't tested before selling it. To sell at a lower price, they are made with lower quality materials which have a much less consistent success rate. The chances of getting Racelands that will fail (mildly or catastrophically) is greater. Your life as a driver depends on safety, and suspension is one of the most crucial aspects of the cars performance. You should always buy superior quality suspension parts. [/quote]
great, that makes perfect sense, now i understand thanks for the input!
159
Jul 5, 2015 09:54 PM
dinsum
May 28, 2015 09:30 PM
iamboo
Mar 21, 2002 12:30 PM
Ramen
Jan 29, 2002 04:35 PM
EsineN
Jan 22, 2002 08:52 PM
