02 em2 suspension
Old Feb 7, 2013
darioo0's Avatar
darioo0 is an unknown quantity at this point
Lightbulb 02 em2 suspension
ok i have a 2002 civic lx which i wanna lower.. im thinking of getting some kyb shocks and skunk 2 coilover sleeves. now the kyb shocks are for the ep3 which have a 16mm hole if i believe so, now will they fit my car?? or would i have to resize to fit the 14 mm.?? and if so how could i do that?
Old Feb 7, 2013
GolNat's Avatar
Prelude Owner
Re: 02 em2 suspension
All you need is reducing washers, found here:
http://ksportusa.com/b2c/proddetail.php?prod=RW0001
Also you should get Ground Control coilovers ( they are better).
How low are you planning to go? I believe kyb's are OE replacements.
Old Feb 7, 2013
Kennykid2002's Avatar
Kenny the Ricer
Don't buy Junk2's
Old Feb 7, 2013
darioo0's Avatar
Well im planning on going a few inches lower maybe like 2-3 inches..right now i just have lowering springs but i want something pretty legit that will last me but yet not over $1000.. so u think the kyb n skunk2 coilover sleeves isnt a good combination?? Cuz all i want is a smooth ride n be able to lower n lift my car
Old Feb 7, 2013
GolNat's Avatar
Prelude Owner
2-3 inches is a pretty good drop. The skunk 2 spring rates might not be high enough. Not sure if the kyb's can handle that low of a drop or a high spring rate (maybe someone else will know, or search). If you get GC's they will match your rate and sleeves to the shocks that you have. They will also tell you what will work the best.
The lower the drop, the worse the ride. If by smooth ride you mean more on the softer side.
Old Feb 7, 2013
bobbyg5502's Avatar
bobbyg5502 is an unknown quantity at this point
I swapped the ep3 suspension onto my 01 lx, because I needed new shocks so i did the whole car. I used a 5/8 drill bit to drill out the knuckles. It was a rather simple task. If you want to use ep3 shocks thats all you need to do.
Tedverseti
Apr 23, 2020 01:45 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
czarlun
Sep 14, 2015 08:16 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
