Balljoint
Old Jun 16, 2011
TDC2001civic's Avatar
TDC2001civic is an unknown quantity at this point
Balljoint
Okay so i got my new balljoints pressed into my knuckles and they have a 90 degree zirk fitting threaded into top, but now my cv shaft doesn't seat into the knuckle correctly, anyone have this issue with balljoint replacement?
the balljoints are from autozone
Old Jun 17, 2011
Re: Balljoint
who was it that said they had balljoints with zirk fittings? And how did you get the clearance to run them?
Old Jun 17, 2011
lazlong's Avatar
Re: Balljoint
Zirk fittings won't fit. Grease the joint, then remove the fitting and plug the hole.
Old Jun 17, 2011
link7's Avatar
link7 is an unknown quantity at this point
Re: Balljoint
I have Moog ball joints on my 2005 ex and I had no problems getting the axle back in after putting the zirk fittings in. I left them in with no problem. I guess it depends which brand ball joints you're using. Dumb question, but are you sure they're pressed all the way in? Are the zirks screwed in all the way?
Old Jun 17, 2011
Re: Balljoint
yeah they were pressed in all the way and zirks tightened all the way down, dumb question from ne now lol, is the zirk located on the top of your balljoint with a 90 degree zirk
Old Jun 17, 2011
lazlong's Avatar
Re: Balljoint
^^ yes
Old Jun 20, 2011
link7's Avatar
Re: Balljoint
Yes on both
BlueEM2
Suspension DIY
35
Nov 7, 2018 05:23 PM
sl33pyriceboi
Suspension DIY
31
Apr 17, 2015 07:31 PM
flirp
Nov 9, 2014 12:49 PM
Hushx
15
Dec 17, 2013 04:52 AM
LiquidArrogance
Apr 4, 2012 03:25 PM
