D17A2 removal - lift it out or drop it out the bottom?
Old Jun 19, 2011
trickyrabbit's Avatar
trickyrabbit is an unknown quantity at this point
I have a 2003 Civic EX sedan, 5-speed with A/C. The book says lift the car, drop the sub-frame and lower the engine out the bottom. Can I lift it out with an engine crane as I have no vehicle lift available. Please don't tell me that you "should" be able to, or you "think" it can be done. Let me know if you have done this and what you had to do. This will not be my first engine pull, but the first one in a civic. Thanks in advance.
Old Jun 19, 2011
Re: D17A2 removal - lift it out or drop it out the bottom?
That's the second thread I know that asks about that. Previous one the answer was yes. Search and you shal find
Old Jun 19, 2011
lazlong's Avatar
Watch this video, it's a '98 but, everything is basically the same.
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=145&t ransactionid=1308533627-7190173246&posted_by=lazlong_www.civicforums.com&y outube_video_id=Me9w6aIqJ48[/autostream]
BTW: This guy has a bunch of good youtube videos.
Old Jun 19, 2011
02civicsi02's Avatar
Low and slow!
Yes you can take it out the top.
Old Jun 19, 2011
TDC2001civic's Avatar
TDC2001civic is an unknown quantity at this point
no no no never try to lift whole car with engine crane cause it can pull the whole crane over. if you want to drop the subframe, you just unbolt the subframe and any connection, but you have to use jacks and jackstands, this method is much more difficult then just cherry picking the motor out the top
Old Jun 20, 2011
mr22508's Avatar
Pistol grip pump in my lap at all times
mr22508 is a jewel in the roughmr22508 is a jewel in the roughmr22508 is a jewel in the rough
I picked mine right out of the top when I replaced my engine.
Old Jun 20, 2011
civic0427's Avatar
civic0427 is an unknown quantity at this point
I just did mine a couple of months ago. I pulled it right out of the top with the transmission still attached. I was very easy. All I did was lift the side with your pulleys first. Pulled it at an angle. Transmission the lower side. There is a thread on here about it but definitely easier from the top without using a lift.
Old Jun 20, 2011
here it goes
https://www.civicforums.com/forums/3...e-removal.html
'nother:
https://www.civicforums.com/forums/7...gine-swap.html
'nother one:
https://www.civicforums.com/forums/7...ng-engine.html
and so on...
search and you shall find...
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
mohawkboom
67
Aug 25, 2015 12:28 AM
old97civic
Jun 28, 2015 10:55 AM
wasa67
Jun 27, 2015 01:47 AM
juror
May 26, 2015 06:35 PM
