Stage 2 NA build questions - Haters keep out
Re: Stage 2 NA build questions - Haters keep out
the spec that I put in for another motor was for a race d16 that has a compression ratio of 13.6 to 1 and I got 10.8 to 1 of course that did not factor in the fact that the head had been cold welded but the cold welding I don't think should have bumped the compression up that high but it could have.
I never heard of it either...
http://en.wikipedia.org/wiki/Cold_welding
Official Rattlesnake Hunter
cold welding a head is when you use a specail welder or welding technique to fill in part of the combustion chamber. but you can't use a regular welder cause the heat from it will warp the head. machine shop will fill the head and then fly cut it out for the valves to get what ever your desired compression maybe
RSJ
Jul 23, 2015 11:29 PM
Touge
Ottawa
Jul 18, 2015 05:38 PM
Touge
Jul 18, 2015 05:37 PM
NoobyKid
Jul 13, 2015 07:53 AM
