where is the atf drain plug located?
Old Mar 5, 2006
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
so i set everything up for an simple automatic tranny fluid change. went ahead and jacked up the front of my car (03 civic ex automatic) and looked for the drain plug on the at case. after a good 5min looking for the drain plug, im now clueless
is this a procedure that us auto civic owners must take into a professional shop to be done or what? i thought it was be simple as an oil change
Old Mar 5, 2006
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
passenger side about the middle of where the tire sits, there just enough room between the tranny and the frame to fit a 3/8" rachet in there, the bolt doesn't need any socket, it just uses the rachet itself, (the bolt has a square hole)
Old Mar 5, 2006
D17thgen's Avatar
thanks, ill give it another try monday.
in the meantime, does anyone have specific pics of this location?
Old Mar 5, 2006
booba5185's Avatar
sigh, i'll go look, i'm sure i'll be able to find a pic
Old Mar 5, 2006
booba5185's Avatar
here's a pic, it's number 18, and this is a look from the back right hope it helps
Old Mar 5, 2006
streetglower's Avatar
all you need to do is look right under the passenger side and you will see a bolt that has a 3/8 head on it for a ratchet. you cant miss it. it sits right above the lower control arm.
Old Mar 5, 2006
blackdragon's Avatar
blackdragon will become famous soon enoughblackdragon will become famous soon enough
where do u pour it in btw?
Old Mar 5, 2006
you pur it in through the dipstick.
Old Mar 5, 2006
eye_see_you's Avatar
let the devil out
yellow or orage dipstick on top of the transmission under the stock airbox if you have one on still and I hope your changing fluid to synthetic or RED LINE fluid thanks to honda and the crappy transmissions
Old Mar 6, 2006
where can i get a funnel that long and wut fluid should i use i got almost 90k miles
Old Mar 6, 2006
any funnel with a semi long nozzle on it should work. Go to walamrt and in the auto section they have funnels, I bought one of them and it works fine. Ir you can remove the resonator chamber when filling it. Also I would use honda ATF. I have used it for 115K miles now with now problems.
Old Mar 6, 2006
teg91ls's Avatar
teg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trusted
Honda atf is garbage fluid, the only reason they "claim" that only honda atf works is so people have to buy honda fluid thus making them more money.. do yourself a favor and get redline or some synthetic like was mentioned.. i just changed mine with mobil 1 atf,, took it for a drive shifts good.
Old Mar 8, 2006
teg91ls's Avatar
good luck changing the tranny fluid yourself too,, it is a bitch and a half because of where they placed the drain plug hahahaha,,, honda loves to make **** difficult
Old Mar 8, 2006
booba5185's Avatar
no it's not....it's the easiest thing i've ever done to my car, dont use an extension on the rachet
Old Mar 8, 2006
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
agreed. i believe BG did a test on a bunch of atfs including honda and honda's atf only lasted 12 minutes of testing. it was the worst out of all the other atf. ill try to get a picture of the survey. the best one was BG universal synthetic trans fluid which i just put in my car and boy was there a big difference. smooth shifts all over. plz dont waste your money and get something better.
Old Mar 8, 2006
mrDFWmechanic's Avatar
wow i'd really like to see that, very interesting
Old Mar 9, 2006
crazyasian's Avatar
yea ill see if i can borrow it or see if i can get a copy of the chart to you guys.
Old Mar 9, 2006
TemjinX2's Avatar
if it helps, the bolt has a little bit of blue paint on it. At least it did for my 04.
Old Apr 1, 2006
PiNoYxRaCeRxRH's Avatar
PiNoYxRaCeRxRH is an unknown quantity at this point
i saw that chart! that chart is BS it made honda atf look like water! and made theirs the best of course! it's advertising!
Old Apr 1, 2006
kcm's Avatar
kcm
kcm is an unknown quantity at this point
sorry to hog the thread but what about cvt??? i got a stupid hx... still got get the rest of the parts for my k20 swap that has been taking forever to save up... also if anyone does not believe cvt sucks, i already had the tranny crap out after a little over 80k with just using honda atf as recomended... also does anyone know of any other atf for cvt because most say do not use with cvt excep hondas... thanks
Old Apr 1, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
you do know BG makes the honda atf....at least the additives for it.....
Old Apr 7, 2006
R1Style's Avatar
interesting... did you guys measure how much tranny fluid came out then replaced it with the same amount... Or did you just put in a certain amount of tranny fluid according to the owners manual?
Old Apr 7, 2006
CraigW's Avatar
2.9 Quarts
Old May 21, 2011
safusp's Avatar
safusp is an unknown quantity at this point
Re: where is the atf drain plug located?
Hi there,
May be you can help me.. I've 2003 Civic LX and I face the same trouble. I'm trying to locate the ATF drain plug and no luck. Do you have any picture when you did it? Any help is greatly appreciated.
Thanks
Safuvan
chuffsy
May 16, 2015 03:52 PM
markp94
Apr 30, 2015 09:19 PM
silverdevil
20
Jun 2, 2007 04:42 PM
JoeB16
61
Oct 16, 2003 07:58 PM
Grey
16
Jan 27, 2002 11:34 PM
