01-02 to 03-05 Gauge Cluster Swap: DONE! Pics inside w/ Pin removing FAQ & Video
Old Nov 10, 2011
  #391
MindBomber's Avatar
Live for the Twisties
Re: 01-02 to 03-05 Gauge Cluster Swap: DONE! Pics inside w/ Pin removing FAQ & Video
Originally Posted by 01HonderCivic
FINALLY I'm able to post in this thread again...Tried a few times over the last months but it kept saying I didn't have permission to post in my own thread Thanks for fixing it whoever did
Anyways, Glad to see the thread is still helping people. I still have my 'vic and the cluster I installed at the beginning of the thread...I don't know if I'll ever be able to get rid of this car. I've thought about moving on a few times, but for the most part this car has been reliable as hell and I can't argue with that
I fixed it, but I still have no idea what triggered the change in your user permissions because none of the admins altered them. If it ever happens again let me know and I'll get it fixed for you.
In my opinion, this is one of the truly great threads in the sites history
Old Dec 4, 2011
  #392
StevenM727's Avatar
StevenM727 is an unknown quantity at this point
Question Re: 01-02 to 03-05 Gauge Cluster Swap: DONE! Pics inside w/ Pin removing FAQ & Video
Hi i have a questions i have a 2001 Honda civic ex 4dr and im getting my engine replaced the engine haves 126k miles and the gauge says 126k and im getting a 2003 civic ex engine that haves 66k miles so my question is can i put the gauge from the 03 civic on my 01 civic and will it say 66k miles ? will it even fit ?
if i leave my old one will it still say 126k?
Old Dec 4, 2011
  #393
Hardcoresteve's Avatar
Hardcoresteve is an unknown quantity at this point
Theres a whole lot of info on this site explaining the cluster swaps, but just leave ur cluster in. The mileage is stored in the cluster though. It wont change because your engine is changed.
Old Mar 1, 2012
  #394
skarface23's Avatar
skarface23 is an unknown quantity at this point
Hello everybody have a quick question about this swap.I just received my new cluster out of a 2004 civic lx (blue one)led..Im swapping into my 2005 civic vp no tach.I printed out the diagrams and were matching the wires on my paper checking with connector to see if it all matched before i go and start rewiring.My problem is theres an extra wire in the new cluster 2004 lx.on the bottom of green plug theres a white/blue after the blue/red and before blue/yellow.what is this white/blue wire??????and if it helps the new cluster is cdm and is in kmh going into my usdm civic.
Old Mar 2, 2012
  #395
I think its for abs light, but dont quote me on that.
Old Mar 2, 2012
  #396
in canada it could also be for the low washer fluid light that usdm cluster/cars do not have. nope guess not, elec manual says its canada wire for headlights. more than likely DRL (daytime running lights) related, which again usdm cars do not come with. the canada clusters have a DRL icon light to show whether the system is working. i bet thats what your wire is for.
Old Mar 2, 2012
  #397
skarface23's Avatar
Thanks for the replys guys.I guess well find out tommorow when i do the swap ive done my homework got the tools this should be fairly easy.Since my car is not gonna have a wire for that spot guess it doesnt matter whatever light stays on is gonna be that wire.unless i ground it would that turn off the mystery icon if there is one?
Old Mar 2, 2012
  #398
skarface23's Avatar
Just found this, and GEARBOX was right its gonna be the drl.So if i ground this spot will it prevent the light from coming on?
Here is what each wire does. The wire pinout i have to send it to you by email cause its in microsoft excel format.
GREEN Connector:
Blue: From ECM/PCM, Tach input signal
White/Red: Constant 12 v +
Yellow: Switched 12V+
Blue/White: From ECM/PCM And VSS input signal
Yellow/Black: From fuel level sending unit
White/Green: From multiplex control unit
Black: Ground
Pink: (Canada Vehicles only) Washer fluid level switch
White/Blue: (Canada Vehicles only) DRL Control unit
Black/Yellow: Security control unit
Blue/Yellow: Cruise control unit
Pink/Blue: OPDS unit (Side airbags)
BLUE Connector:
Black: Ground
green/orange: From ECM/PCM
Blue/Red: From ABS Control unit
Pink: From SRS unit
Red/Black: Supplies 12V+ for dash backlights
Red: Supplies switched ground for dash lights
Green/Red: Left turn signal indicator
Green/Yellow: Right turn signal indicator
Red/Blue: Combination light switch
Blue/Orange: Immobilizer control unit
Red/Yellow: From no 15 fuse under hood
White/Red: From no 9 fuse under hood
Yellow/Red: From oil pres switch
Old Mar 2, 2012
  #399
Yea sorry I was wrong. I was just guessing as to something the vp cluster wouldnt have. I was going to swap the blue cluster in, but I just got the bezel with gauge pods in it instead.
Old Mar 4, 2012
  #400
i think the only light that comes on by leaving the wire disconnected is the abs. the washer fluid, side srs, and drl should stay off without doing anything. just tape up the wire. if it does come on for some reason, then you can try grounding it.
Old Mar 5, 2012
  #401
tony nmn's Avatar
tony nmn is an unknown quantity at this point
i need some help. i bought a 2004 civix dx. the previous owner said the instrument cluster went bad and he replaced it .i said cool how many miles etc.125000 ok. i asked if i could the old cluster with the car. here were i get confused the one he gave me the old one has a rpm gauge and is different the then the one thats in it. so i buy a used one like he gave me .plug but no play. my question is did any dx 2004 come with a instrument cluster with a tach. if not how can i make it work
Old Mar 5, 2012
  #402
01-05 civic dx/vp only came with basic clusters (no tach), but the 01-02 lx/ex clusters with tach should be a direct swap just plug it in. the 03-05 lx/ex fancy led clusters (red or blue rings) need rewiring and this is what the thread here is about to repin the connectors to a new config.
Old Mar 7, 2012
  #403
tony nmn's Avatar
thanks is there any way you could send me a print of what i have know with the green and blue plug and what it needs to be converted to green and blue plug. i know this is asking alot but i would appreciate it alot. if you want to email it to me at tony939500@charter.net that would be great and thanks for your time and knowledge
Old Mar 7, 2012
  #404
everything you need should be in this thread, including the two conversion diagrams. here they are again tho
Old Mar 24, 2012
  #405
paulymcd7's Avatar
paulymcd7 is an unknown quantity at this point
Can someone post or repost how to remove the pins in the wire harness is there a video? I couldnt find it here
Old Mar 24, 2012
  #406
01HonderCivic's Avatar
Don't be a n00b, search ftw
Dude, Look at the first post...I have a link to the video I made years ago how to remove the pins.
Old Mar 28, 2012
  #407
paulymcd7's Avatar
the white/red wires.. does pin 15 on green get moved to pin 17 on green? and if so what happens to pin 1 on the blue vp connector? because it doesnt have a pair on the blue ex connector
Old Mar 28, 2012
  #408
paulymcd7's Avatar
also i have a blu/red wire does that mean i have abs?????
Old Apr 18, 2012
  #409
lazlong's Avatar
Alright, whose gonna sell me their '01-'02 EX cluster w/o side airbags? Speedo has to work correctly. I also have an '04-'05 cluster with a broken lens if you want it. Need it ASAP to get out of a ticket so, PM soonest.
Old Apr 19, 2012
  #410
dgreen78's Avatar
dgreen78 is an unknown quantity at this point
I have a few clusters from 01-02 and 03-05 auto and manual versions. I can put any mileage you like on them as well.
PM me if you are interested.
Old Apr 19, 2012
  #411
paulymcd7's Avatar
i just want to know how to change the mileage lol i need it rolled back 62k and change
Old May 1, 2012
  #412
concepttheman's Avatar
concepttheman is an unknown quantity at this point
Ok this is one of the older threads in the world.
Here is the senario:
I got jerked and bought a 2000 honda civic lx 4 door auto matic
97k and not that rusted for under 2400
Had hell with it....welll not really i did a minor tune up and gotta change the lower 02 sensor.
The problem is im missing the glass/plastic cover over the odometer.
I can get a new glass only for 40 from the dealer.
I searched this forum for 2 hours.
Are there clips that i have to buy or any other parts, because the plastic peice is missing.
Anybody that can answer me will get a like.
Also is there a diy video, as i cant find one?
Concepttheman@gmail.com
Thanks!!!
Old May 25, 2012
  #413
jlee's Avatar
jlee is an unknown quantity at this point
Hi Guys,
I known this is a very old post..but it's still ROCK...
I just did a swapped from 2004 sedan lx cluster to my 2005 sedan vp (usa). I still have one wiring left afterward (i believe it's a red/white (or white/red)). Everythings in perfect lite-up..accept the door open indicator...is the leftover suppose to be the door open indicator? do you guys know which pin for the door indicator? I cannt find it from the diagram...any suggestion?
Thanks
Old May 26, 2012
  #414
Originally Posted by jlee
Hi Guys,
Thanks
That was the only wire I had left over...I just let it hang like that. Honestly, door indicator is really the least of my concerns...I think I'd be able to tell quick if one of my two doors are open
Old May 26, 2012
  #415
civics do not have door open indicators, only a trunk open indicator
Old May 28, 2012
  #416
jlee's Avatar
thanks guys...then what is the purpose/function for the leftover wire? it must be use for something...any clue?
Old May 28, 2012
  #417
https://www.civicforums.com/forums/1...ml#post4174905
The answer was posted earlier in this thread, but there's the link again. Red/White goes to fuse #9 under the hood...find what that fuse controls, and you have your answer.
Old May 28, 2012
  #418
^ OPDS unit for side-airbag (in the seat). and i think only the EX had the "side-srs" indicator light on the cluster.
Old Jul 8, 2012
  #419
Hensinger2010's Avatar
Meh...
Hensinger2010 will become famous soon enough
bump ^
Old Aug 16, 2012
  #420
logicdc's Avatar
logicdc is an unknown quantity at this point
I did an 02 EX coupe to 05 EX coupe cluster swap. I have side airbags but the new cluster doesn't. My original cluster was very boring and found a nicer 02 cluster that matched in mileage so I swapped that in two years ago. That cluster did not have side srs either.
So my post is because with the new cluster swap, the SRS is lit. I assumed because the donor car had a head on collision. So I did the SRS reset (took me 4 times but got it.) Started the car this morning, no light. Drove 0.1 miles and it came back on. 4 restarts - still on.
After work I checked the main SRS fuse under the dash but it is good. I have not checked the side srs fuse but since it is not the one feeding the light I skipped it for now.
Since the cluster was the variable, I posted here first. I bought green and blue clips and did a pin by pin swap. I did not pull the battery cable but I was very careful. Nothing is blown or else is effected. Any ideas?
TIA
