Update for EMANAGE: WORKING SETUP FOR EXs!!!
Old Jul 21, 2004
  #31
dezod's Avatar
7thgen Power Maker
Mad, Did You Try To Bump Up Vtec Engagement To 5k?
Old Jul 21, 2004
  #32
dezod's Avatar
7thgen Power Maker
We are getting VTEC. I confirmed it with the Honda Diagnostic code reader. The VTEC enagages, but the switch turns on and off sparatically according to my buddy who came along for the monitoring.
Old Jul 21, 2004
  #33
HyaBoosta's Avatar
is it possible to just not connect the emanage to the vtec at all?
Old Jul 21, 2004
  #34
dezod's Avatar
7thgen Power Maker
SURE
Old Jul 21, 2004
  #35
HyaBoosta's Avatar
would there really be a big benifit to lowering the vtec engaugment on boost?
Old Jul 21, 2004
  #36
dezod's Avatar
7thgen Power Maker
Only benefit would be to help TQ or HP "fall-off" points when dyno tuning. If for example, there is a nice dump off on TQ @ 4200 RPMS, but your VTEC is set to engage @ 4900 RPMS....You can adjust the VTEC down to help "patch" that fall off on your numbers so your dyno curves are more smooth that spikey.
Old Jul 21, 2004
  #37
HyaBoosta's Avatar
i see good info.
Old Jul 21, 2004
  #38
HyaBoosta's Avatar
but wouldn't the vafcII do this easily. the only beifit i can see of the emange is the ignition timing.
Old Jul 21, 2004
  #39
dezod's Avatar
7thgen Power Maker
E-Manage:
1. Injector Duty Cycle
2. VTEC Engagement
3. AIR/Fuel
4. Data Logging
5. Map Tracing
6. Timing
7. GReddy Pressure Sensor
8. Sub Injector Controller
9. Boost limiter cut
10. Anti-engine stall
V-AFC II
1. VTEC Engagment
2. AIR/Fuel
E-Manage > A'PEXi V-AFC II
Old Jul 21, 2004
  #40
HyaBoosta's Avatar
i guess i'll base my decision off of this thread to see if everything can be hooked up and running right.
Old Jul 21, 2004
  #41
MadWheel's Avatar
Premium Boosted Member
I am about to go hook this thing up to do everything but VTEC. Hopfully we can find something that works. Dezod is attempting the same as we speak. Both of us should have a solution soon.
Old Jul 21, 2004
  #42
MadWheel's Avatar
Ok we tried every setting there was.
Final Verdict:
With what we see on the boards, and with what Greddy gives you, there is know way to properly control VTEC on 01-04 Civics. 4-8-E works, hooked up and all, but the VTEC is electronic only, meaning the VTM wire is still on the low cam.
The emanage thinks it's changing VTEC, and logs it, but VTEC wont kick in because the only jumpers that work are set to not use a VTM.
4-8-C is what I ended up going with. I have the exact same setup as Optoisolator whcih works EXTREMELY well. My car has rediculous top end, because I left all the VTEC wiring stock (nothing VTEC touches the emanage). The settings 4-8-C require you to set the jumpers inside to control VTEC, but you don't have to wire it. The only thing you have to do use check off the air flow adjustment map under your parameter settings and you'll be fine. Once again, opto started this and deserves credit for those findings. I added some fuel to my top end and it feels pretty nice. Doesn't bog down either so the safer the better.
Only other possibility: If you hook up 4-8-C and wire the VTEC system into it (purple, light blue, yellow) you have one thing to play with. If you go to parameter setting, on the top right you will see a pull down box allowing you to change your air flow metering. I tried the default which is 3. Once VTEC engages for the first time the engine goes into limp mode and wont rev past 4k (even with the deadband set correctly). I tried Air flow 1, and it through a CEL instantly, and went into limp mode before I even engaged VTEC once. I have an OBDII scanner, and it shows that I had an air flow meter error. The only thing I can think of is to manually change the air flow metering settings to each one and see what happens. One of those MAY do the trick.
Until then, I can now adjust my fuel and my VTEC works fine. I don't see the need to change it, right around 4200rpms my car pulls like a motha! I will soon be able to adjust ignition timing and crank up the boost a little more, once I get more familiar with the software. Until then, I'm happy. Hopfully you guys get this right the first try and save yourselves the aggrevation. Good luck and happy tuning!
-Joe
Old Jul 21, 2004
  #43
HyaBoosta's Avatar
can you post up the final screen shot of the settings?
Old Jul 21, 2004
  #44
MadWheel's Avatar
yeah i will tomorrow... laptop is still in the car and im about ready for bed...
Old Jul 22, 2004
  #45
dezod's Avatar
7thgen Power Maker
Joe and I spent about 40 minutes on the phone last night trying settings and different wirings. This setting is the best by far....Great work Joe & Opto.............GREAT WORK originally. Optop your a life saver.
So all in all.....The E-Manage is ready to romp 7thgens on these settings.
Old Jul 22, 2004
  #46
dvsdara's Avatar
dvsdara is an unknown quantity at this point
Glad I read up on this thread. I'm getting all the info I need to know so when your kit comes out Dezod, I'll be purchasing that as long as my funding is available. I also have the convenience of living not too far from Joe so I can always give him a call to help me out with it. Good stuff tho guys.
Old Jul 22, 2004
  #47
HyaBoosta's Avatar
so were theese settings put in after the vtec wiring was removed or is the vtec wiring still on?
Old Jul 22, 2004
  #48
dezod's Avatar
7thgen Power Maker
Internal jumpers were left the same.............
Rotary settings set to 4-8-C
No VTEC wires were connected (VTEC in, out or VTM)
Old Jul 22, 2004
  #49
MadWheel's Avatar
Make the emanage think it's set for a VTEC engine. When you choose your parameter settings, make sure to not check off VTEC and then you'll be all set. I am only adjusting fuel right now and it definately works.
I'll be hopfully taking it to the track tomorrow night to see if it's helped yet, even without dyno tuning. Once I have money again I'll be hitting up a dyno to really get it set up right.
Old Jul 22, 2004
  #50
opto_isolator's Avatar
Or - if you really want to get creative - you might be able to enable vtec, and use the output as a shift light!
Old Jul 22, 2004
  #51
dezod's Avatar
7thgen Power Maker
Creativity like whoa! LOL
Old Jul 28, 2004
  #52
Arcan3's Avatar
Arcan3 is an unknown quantity at this point
is there suck a thing as a vtec controler that doesnt control Air/fuel? wut emanage is this?
does this affect the rev limiter in any way?
Old Jul 28, 2004
  #53
Arcan3's Avatar
will it work for an auto ex?
Old Jul 28, 2004
  #54
Jeff's Avatar
Jeff is an unknown quantity at this point
Hey madwheel, have any settings for a dx/lx jumper settings. Mine will be here soon and since you have messed with it the most, any info would help .
Old Jul 30, 2004
  #55
MadWheel's Avatar
Dezod has an auto too.
The settings I used will work for you. Just don't hook up the VTM wire, or the 2 VTEC wires and it will work. Leave everything else the way I hooked mine up which was posted earlier. This is the same setup as optoisolator.
Old Jul 30, 2004
  #56
Jeff's Avatar
I found a picture of the emanage circuit board. If you want you could use this in a diy showing the correct jumper settings. (the jumper setting in the picture are not for our cars, i just found it on the internet).
http://www.mohdparts.com/emanage/pho...cuit_board.jpg
Old Aug 1, 2004
  #57
canadian2k1si's Avatar
canadian2k1si is on a distinguished road
E-manage setup for Boost on 2001 EX
I am still looking for a base map to use before I start dyno tuning, if anybody knows of where I can get one it would be greatly appreciated. But for anyone who is having trouble getting the wiring, & jumpers & switches set properly for the 2001 EX (With VTEC), here is what I have:
JP 1 1-2
JP 2 2-3
JP 3 2-3
JP 4 1-2
JP 5 Open
JP 6 Open
JP 7 Open
If I have JP 4 Set to Open, I get an error 14 When I turn the car on, "VTEC Signal Input Error."
Switch Settings:
4-8-C Works for me,
4-8-B Blows the 15A Coil Pack Fuse!
My Injector Settings are:
CH-1 Inj 1
CH-2 Inj 3
CH-3 Inj 4
CH-4 Inj 2
My Ignition Settings Are:
CH-1 Cyl 1
CH-2 Cyl 3
CH-3 Cyl 4
CH-4 Cyl 2
These settings seem to work for my car, but I am having a strange problem:
When I first start the car after being off for a while, the "Error 14 Code" Appears, saying I have a "VTEC Signal Input Error." But If I turn off the car, and back on it just goes away....?? This is very strange, and I think it might have something to do with the oil pressure not being at a certain level or something until the car warms up, any ideas on that one? Sometimes it does not do it though!
My other confusion is at 2000. 3000, 4000, 5000 & 6000 rpm the green light turns a solid Orange/Red! I wonder why?
I notice that in the Support Tool, Parameter Setup Where I am using;
HN_PR-1 for the Air Flow Meter Change
The A.A.V. Rpm Setup Uses these Rpm points. Is this a problem, or is it just showing me it is doing something?
I still have not received my entire turbo setup from SF yet, but I am trying to get this e-manage under control first.
Old Aug 1, 2004
  #58
I found this on the Yahoo e-manage support group;
JP1 Ignition input pullup/pulldown select
1-2 A resistor is pulled down to ground
2-3 A resistor is pulled up the +ve rail
* Use 1-2 when the ECU's driver transistor is
connected to ground
* Use 2-3 when the ECU's driver transistor is
connected to +ve (5V or 12V will determine JP2's
setting)
Supposedly you can see the input voltage in the Main Unit Setting
Information window. If it's 0v, use 1-2. If it's 5v or more, use 2-
3.
JP2 Ignition output select
1-2 Output resistor connected to +5V
2-3 Output resistor connected to +12V
* This will depend on the ECU ignitor signals output
* JP2 enables the e-manage to duplicate the amplitude
of the original signal
JP3 airflow/VTEC output select
1-2 2nd airflow meter
2-3 VTEC
* Even if you don't have a 2nd airflow meter, leave it on 1-2 for
non-
VTEC applications
JP4 airflow/VTEC input select
1-2 VTEC
2-3 2nd airflow meter
* Even if you don't have a 2nd airflow meter, leave it on 2-3 for
non-
VTEC applications
* On 1-2, enables pulldown resistor (for use as VTM signal). This
is
required because the VTM output is inverted with the VTEC out.
JP5/JP6 Sub injector drivers
Jumper off - Disabled
1-2 - Enabled
* Only enable if you're going to control extra injectors with the E-
manage
JP7 VTEC
1-2 Non-VTEC
Jumper off - VTEC
* On 1-2, enables pullup resistor (for use as MAF output)
Old Aug 1, 2004
  #59
JP 1 1-2
JP 2 2-3
JP 3 2-3
JP 4 1-2
JP 5 Open
JP 6 Open
JP 7 Open
Switch Settings:
4-8-C Works for me,
CH-1 Inj 1
CH-2 Inj 3
CH-3 Inj 4
CH-4 Inj 2
CH-1 Cyl 1
CH-2 Cyl 3
CH-3 Cyl 4
CH-4 Cyl 2
Disable the vtec setting in the support tool. If you don't have it enabled, the emange will not give you an error. Zero out the AAV - they are useless when you have the support tool.
Old Aug 1, 2004
  #60
Havok2k1's Avatar
Wicked Pissah Admin
There's already a thread in Tech about hooking up and running the e-manage that is stickied. Lets try and keep all this VERY useful info in one spot for people....
http://www.7thgencivic.com/forums/sh...d.php?t=164441
