What did you do to your civic today?
Old Dec 13, 2017
  #2461
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
Re: What did you do to your civic today?
Dyno Sheet pic.
Old Dec 13, 2017
  #2462
Oh damn. Nice. Odd to see a higher torque number than HP number on a civic. lol
Old Dec 14, 2017
  #2463
piano55man's Avatar
And then there was a clatter on the drive home and the engine stopped running...i think i dropped a valve
I pulled the valve cover and didn't see anything visually wrong, but that's not saying much. Pulled all the accessory belts hoping maybe the ac or alternator locked up...nope, everything still spins.
The engine did start up with a bunch of clatter coming from the what appears to be the top of the engine specifically near the cam pulley side....
No matter what happened, i'm pulling the engine and starting the big build project! going after 300+ HP!!!!!
Old Dec 14, 2017
  #2464
^ Cam pulley bolt isn't tight? ^
Old Dec 14, 2017
  #2465
piano55man's Avatar
It might have come loose...
We also have to keep in mind, this engine has 265,000 miles on it.
Everything is original except for the water pump, oil pump, injectors, cam gear, time belt, and Head studs.
When i installed the AEM cam gear, I tighten the **** out of it along with using red locktight. It might have come loose...but i highly doubt it. This is on the check list of checking when tearing down.
Also, on the dyno we ran this at 7,000 rpms....
So there is a laundry list of items that could have let loose.
I will be documenting everything on my Ktuner and the D17 thread after then engine is pulled out.
Old Dec 17, 2017
  #2466
piano55man's Avatar
Rod bearing melted to the rod end
Old Dec 18, 2017
  #2467
Found a decal laying around from when I had a run of them made. Decided to christen Miyuki with a blessing from the forum.
Before anyone asks, I do not have any more laying around. I still have the vector files somewhere though. PM me if you want it, and I'll discuss the intricacies via PM. Maybe I'll run it up to Civicforums IB staff to see if there's a way to have decals available through a forum store or something. Slight tangent, I remember back when 7thgencivic.com (what civicforums was before the site sale) had a store and you could buy decals, license plate frames, t-shirts, etc.. I still have a shirt or 2 laying around from the good ol' days. lol
Old Dec 19, 2017
  #2468
ooh nice
I would be interested in a sticker or 2
Old Dec 19, 2017
  #2469
mine, just for the fun
outlined, black inside, so matches the car color
Old Dec 19, 2017
  #2470
That one was the most expensive one bc metallic vinyl. Theres a layer of silver exposed between the black and red
Old Dec 20, 2017
  #2471
But fit so well, as I pictured, worth every penny
Was I the only one to place it on the body?
Old Feb 10, 2018
  #2472
On today's edition of "Josh said he wasn't gonna mess with the new Civic but keeps doing **** anyways," I present to you something from across the pond. Apparently, the 10thgens were equipped with engine side covers to cover up the 4-6" dead space between the engine bay and the fender. Why they nixxed it for the US release is beyond me. For Honda OEM from the UK, it'd cost like $200. Hell no. I found aftermarket OEM fit ones on Amazon for $55 shipped. That'll do pig, that'll do.
first things first, a before pic. I snapped this when I installed my HIDs to showcase where I mounted the ballasts. You can see the aforementioned dead space, and they used said space on the passenger side to house the windshield washer fluid reservoir. The other side is straight up empty. Don't mind the red arrow. That was for another question I had way back when.
Size:  71.1 KB Name:  n3y7e9Bl.jpg
And here's a pic from 5 minutes ago
The Amazon listing said it came with hardware, but that ended up being a buncha malarkey. Pep boys had nylon screw-type rivets and they fit nicely. Also had to drill a 1/4" hole in the passenger side radiator support. Instead of using paint to seal it up, I grabbed a gun bluing pen to make a nice little black oxide layer to protect it, then put the screw-type nylon rivet in place. Look OEM AF, yo
Old Feb 10, 2018
  #2473
Also decided to turn an old Sparco seat into an office chair. Second time ever welding (first time was yesterday and I ran practice beads on some scrap steel). Not bad for a beginner, IMO. If any of you welding veterans have any tips for a newbie like me, feel free to bestow your knowledge upon me (like how to minimize the damn splatter. lol). I was using a flux-core gas-less welder (.035" wire), and used the settings suggested on the machine, tweaked a bit (1/8" steel, wire feed rate 55in/min, arc voltage 17-17.5V).
Seat is faded and beat to ****, but it's comfy as all hell.
All my weld joints look about like this. This might've been one of the better ones.
Old Feb 10, 2018
  #2474
This is the reason it spatters. Use MIG instead (if possible)
Old Feb 10, 2018
  #2475
I figured that was the case. Saw the same issue with flux core torch brazing. I didn't know if I was doing something wrong or not. Unfortunately, my pops is too cheap to buy gas tanks for his MIG welder, so I was stuck with what I used. Good to know that I'm on the right track, at least. At least I know how to use an angle grinder to level things out
Old Feb 12, 2018
  #2476
Felix ES1's Avatar
Felix ES1 is an unknown quantity at this point
New headlight LEDs cause i couldnt see in the night at all
Old Feb 12, 2018
  #2477
I can't say much, I got the dirt cheap China Freight flux core welder
Old Apr 6, 2018
  #2478
piano55man's Avatar
Almost finished with the newest edition of my turbo build.
Waiting on a few things...
New fuel pump. (should be in early next week)
800cc injectors come in today.
exhaust to be tig welded this weekend by a buddy of mine.
Cleanup wiring looms and reroute vacuum lines.
Oh yeah...tune...lol
ID:	112108   Click image for larger version
ID:	112109   Click image for larger version
ID:	112110   Click image for larger version
Old Apr 23, 2018
  #2479
"Doctor Cosmo Kramer, proctology."
Old May 10, 2018
  #2480
Refinished the rims, need to find my tire shine
Old May 10, 2018
  #2481
piano55man's Avatar
Car looks nice and clean!
Old May 10, 2018
  #2482
Thanks! Got it from my grandfather 2 Decembers ago, he didn't drive much
Old Jun 4, 2018
  #2483
piano55man's Avatar
Exhaust thru the hood finished!
ID:	112282   Click image for larger version
Old Dec 21, 2018
  #2484
Had a go at vinyl wrapping today .not bad for $8
Old Dec 21, 2018
  #2485
piano55man's Avatar
Thumbs up Re: What did you do to your civic today?
nice!!!
Old Dec 21, 2018
  #2486
GolNat's Avatar
Prelude Owner
Looks great!! Nice price too.
Piano55 the hood exhaust looks great too!!
Old Dec 21, 2018
  #2487
Sorry. Was mistaken on the price.. It was $5 for the 12" x 12" sheet of 3M 1080 carbon fiber vinyl.. shipped. From Amazon.
That vinyl is pretty forgiving stuff
edit:
here's a link to what I bought, for anyone that wants to give it a go here's a link to what I bought, for anyone that wants to give it a go
. Now that I have some experience with it, I'm probably gonna do my outer door pillars with the same stuff. A 1' x 5' roll, with toolkit, I found on Amazon for $22 shipped
Last edited by xRiCeBoYx; Feb 21, 2019 at 01:56 PM. Reason: I'm dumb and forgot to link it
Old Feb 21, 2019
  #2488
5500k LED high beams went in today. It also snowed last night here in Vegas.
Yesterday, installed an OEM Accord Homelink module in my overhead map light console.
A few days ago, LED turn signals went in, along with V-LEDs VLR-3 load resistors (one per side). Now my turn signals are bight af with that instant-on look, and no hyperflash.
Some weeks ago, did an ECU flash tune (KTuner v1.2 -- car's now pushing 21psi boost and ~215hp/260tq from a stock 180hp/185tq)
Old Feb 21, 2019
  #2489
piano55man's Avatar
nice!
Old Apr 11, 2019
  #2490
I ran into a box on the road that had a very familiar question mark on it.. then these appeared on my center console
Someone's about to get f'd in the a
Edit: also "down-tuned" to the 18psi map. Figured I'd save a bit of fuel on my short commutes.
note full boost at 80% throttle.
