Main't Req Light
www.AbsouluteDriven.com
Main't Req Light
Yep... I have a 2003 Civic EX (US) with 8,067 miles on it. I had my oil changed once since i got it. Today when i started my car my Main't Required light flashed for a little and then turned off - and it does it everytime i start my car now. It doesn't stay on though - just flashed for a little - ideas?
The Man, Myth and Legend
From: Western Canada, where the beer is cold and the women are HOT!
Two possibilities.
1.) Change your air filter. It's clogged, and needs to be replaced. If it's a K&N type, clean it.
2.) Standard "pay Honda" light. There is a programmed response in the computer of your car at a certain mileage, the light will come on and you take the car to honda, get the oil changed and they check the brakes, fluids, yada yada yada... and charge you like $50-$100 for it. I think, if you don't wanna do this, there is a DIY for you to turn off the light. I'll try to find it and post it for ya.
Sorry. I looked and I couldn't find the DIY. I might be thinking of something else (SRS light maybe).
Take it to the "stealership", and wear your loose pants. Cause your probably gonna take it up the a$$ with their high prices.
Originally posted by obtix
I have a Injen Intake on the car - I actually just cleaned the filter two weeks ago.
OH MY GOD THE LIGHT IS FLASHING??? What ever you do, DON'T read your owners manual, the owners manual is just for taking up space in your glove box, it has usless information. Infact I'd use it to prop up a wobby table because it has no value.
okay okay I'm joking, but doesn't anyone read the manual anymore? This question has been posted more than 15 times in the past year. There are so many things in the manual that can help you, for example, the wrench in your trunk that can manually close a open Moonroof if the battery goes dead or the electric motor fries.
Well... Human Manual (solar) what does it say for my issue if flashes a few times the second the car turns on....
Acutally I just noticed that one of my headlights is out (@&%@#^!) could that be the issue? dumb PIAA lights oh well....
If its the Maintance required light it clearly states in your owners manual that the light will flash at 8,000 miles and will stay on constintly after 10,000 miles, "Until you Reset it!"
it also tells you how to reset it, very very easy, it'll take less than 30 seconds.
Read Your Owners Manual
lots of good info in there that will help you in the future.As far as the headlight goes, if it goes out it won't set off a warning light on the dash, make sure it didn't come unplugged somehow.
werdnahall
May 17, 2015 11:37 AM
jetcare101
May 8, 2015 01:33 PM
Grazzhopper
Nov 11, 2001 08:06 AM
