Main't Req Light
Old Jun 10, 2003
obtix's Avatar
www.AbsouluteDriven.com
obtix is an unknown quantity at this point
Main't Req Light
Yep... I have a 2003 Civic EX (US) with 8,067 miles on it. I had my oil changed once since i got it. Today when i started my car my Main't Required light flashed for a little and then turned off - and it does it everytime i start my car now. It doesn't stay on though - just flashed for a little - ideas?
Old Jun 10, 2003
ZMan2k2's Avatar
The Man, Myth and Legend
From: Western Canada, where the beer is cold and the women are HOT!
ZMan2k2 is an unknown quantity at this point
Two possibilities.
1.) Change your air filter. It's clogged, and needs to be replaced. If it's a K&N type, clean it.
2.) Standard "pay Honda" light. There is a programmed response in the computer of your car at a certain mileage, the light will come on and you take the car to honda, get the oil changed and they check the brakes, fluids, yada yada yada... and charge you like $50-$100 for it. I think, if you don't wanna do this, there is a DIY for you to turn off the light. I'll try to find it and post it for ya.
Sorry. I looked and I couldn't find the DIY. I might be thinking of something else (SRS light maybe).
Take it to the "stealership", and wear your loose pants. Cause your probably gonna take it up the a$$ with their high prices.
Old Jun 10, 2003
obtix's Avatar
I have a Injen Intake on the car - I actually just cleaned the filter two weeks ago.
Old Jun 10, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Searching for this has now been greatly simplified since its in the STICKY on top of the forum.
Old Jun 10, 2003
ZMan2k2's Avatar
Then you're probably looking at option 2. Sux, but it's the only way to get rid of that dam light. I did it, they don't do much, but what can you do. Unless someone else here knows how to shut off that engine light.
Old Jun 10, 2003
FALKEN's Avatar
Civicforums Junkie
i have personally posted this fix like 5-6 times...try searching the sticky at the top...
Old Jun 10, 2003
ZMan2k2's Avatar
oops... sorry falken
Old Jun 10, 2003
solar's Avatar
solar is an unknown quantity at this point
OH MY GOD THE LIGHT IS FLASHING??? What ever you do, DON'T read your owners manual, the owners manual is just for taking up space in your glove box, it has usless information. Infact I'd use it to prop up a wobby table because it has no value.
okay okay I'm joking, but doesn't anyone read the manual anymore? This question has been posted more than 15 times in the past year. There are so many things in the manual that can help you, for example, the wrench in your trunk that can manually close a open Moonroof if the battery goes dead or the electric motor fries.
Old Jun 10, 2003
obtix's Avatar
Well... Human Manual (solar) what does it say for my issue if flashes a few times the second the car turns on....
Acutally I just noticed that one of my headlights is out (@&%@#^!) could that be the issue? dumb PIAA lights oh well....
Old Jun 10, 2003
solar's Avatar
have you read your manual yet? And you are talking about the maintance required light right? not your check engine light?
If its the Maintance required light it clearly states in your owners manual that the light will flash at 8,000 miles and will stay on constintly after 10,000 miles, "Until you Reset it!"
it also tells you how to reset it, very very easy, it'll take less than 30 seconds.
Read Your Owners Manual lots of good info in there that will help you in the future.
As far as the headlight goes, if it goes out it won't set off a warning light on the dash, make sure it didn't come unplugged somehow.
Old Jun 10, 2003
FALKEN's Avatar
Civicforums Junkie
((((SEARCH))))
Old Jun 10, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
http://www.7thgencivic.com/forums/sh...threadid=96673
-Locked-
werdnahall
May 17, 2015 11:37 AM
jetcare101
May 8, 2015 01:33 PM
leon1
Apr 28, 2015 07:32 PM
Blk01Cpe
Dec 13, 2001 08:34 AM
Grazzhopper
Nov 11, 2001 08:06 AM
