Transmission swap post information/Questions about automatic to Manual Transmission swaps
Transmission problem
Old Oct 5, 2022
kentdom's Avatar
kentdom is an unknown quantity at this point
Hi all, i have a 2001 honda civic. D17a1 below and d17a2 head and tranny (manual). My problem is, my gear shift into gears but it doesnt run. Its like its still in neutral.
Old Oct 5, 2022
Re: Transmission problem
broken cables?
whoever did the swap never did finish the job and it is not connected? hundreds of possibilities, get under there and start checking, prodding
Old Oct 6, 2022
kentdom's Avatar
Originally Posted by sdaidoji
broken cables?
Hi, all cables are in there. I even checked the clutch slave and it's all okay. it even has a new clutch on it. The clutch feels good. I can hear some weird noise if I put it on gears. it sounds like something is sliding or something
Old Oct 6, 2022
BrotatoChip's Avatar
Super Moderator
Is an axle not seated in the transmission? That could cause some grinding noises and would also make it feel like it's not in gear.
Old Oct 6, 2022
OK, so you meant that when you push the shifter lever, it apparently gets into the gears, but it does not move?
Old Oct 7, 2022
kentdom's Avatar
Yes, even if the engine is off. I put it into gears to see if it locks but it doesn't. It feels like it's still in neutral.
Old Oct 7, 2022
Super Moderator
Have you checked this?
em2.kid
Feb 14, 2008 11:35 PM
hpimike
Feb 4, 2008 12:43 AM
mattyg23
Dec 15, 2006 04:11 PM
Silver02EX
May 5, 2004 05:55 PM
hyperactive
Feb 7, 2002 01:07 PM
