7th Gen Head Gasket
7th Gen Head Gasket
1st is about 15ish mins and 2nd is 40ish. this is my second time bleeding the cooling system and had to do it again since my thermostat got air locked. even after 1+ hour of bleeding the system, it was still bubbling. would this coolant colour change indicate a faulty head gasket? should also note i smelt exhaust fumes from my rad while bleeding it.
Re: 7th Gen Head Gasket
If you want further proof that it's a head gasket breach you can do a Block Test on it.
Easy to do, the tester tool is a free rental at parts stores and the test fluid is around $10.
Search YouTube for Block Test.
jimperry6315
Jun 14, 2021 06:28 AM
Niaboc67
Jan 14, 2016 01:09 AM
bosbury1
Sep 7, 2012 08:52 PM
