7th Gen Head Gasket
Old Jan 19, 2022
Hotion's Avatar
Hotion is an unknown quantity at this point
7th Gen Head Gasket
1st is about 15ish mins and 2nd is 40ish. this is my second time bleeding the cooling system and had to do it again since my thermostat got air locked. even after 1+ hour of bleeding the system, it was still bubbling. would this coolant colour change indicate a faulty head gasket? should also note i smelt exhaust fumes from my rad while bleeding it.
Old Jan 19, 2022
BrotatoChip's Avatar
Super Moderator
Re: 7th Gen Head Gasket
Head gasket. Those bubbles are combustion gases leaking passed the head gasket and into the water jacket.
Old Jan 28, 2022
Wankenstein's Avatar
If you want further proof that it's a head gasket breach you can do a Block Test on it.
Easy to do, the tester tool is a free rental at parts stores and the test fluid is around $10.
Search YouTube for Block Test.
jimperry6315
Jun 14, 2021 06:28 AM
Niaboc67
Jan 14, 2016 01:09 AM
civic98?
Nov 10, 2014 08:58 PM
mrohitredd
General
Jan 13, 2014 05:57 PM
bosbury1
Sep 7, 2012 08:52 PM
