No start, no crank, one click
Old Jul 1, 2020
Legofan's Avatar
Legofan is an unknown quantity at this point
2006 DX 90k miles, automatic
​​​​​Randomly would not start since about December 2019. Fiance described it as, "it just did nothing when I turned the key but would start the second or third time I tried it".
Last week it stopped starting, battery voltage is 12.6, load test is good, turn key and you hear a click from starter. It is one single click and nothing else.
I was in the car when this happened, I heard the starter try to turn maybe once then stop. After that, dead, only one click from starter when the key is turned to start.
I have already bought a new starter but I have been reading that it could be many other causes. I have eliminated the key security possibility. I was planning to check the relay in position 7 in the relay box under the hood.
Aside from this does anyone have a recommendation as to whether this sounds like a bad starter? Is this common?
Thanks in advance
Old Jul 1, 2020
Colin42's Avatar
Re: No start, no crank, one click
I would guess bad starter, maybe a bad connection.
Try smacking the starter and see if it will start
Old Jul 1, 2020
Legofan's Avatar
I was planning to do that as well, thanks for the input.
I'm dreading replacing it since it looks like a pain.
Old Jul 3, 2020
Legofan's Avatar
It was the starter, fairly easy swap as well. Thanks for the help.
Old Jul 3, 2020
Thanks for following up on the thread
Old Jul 3, 2020
Legofan's Avatar
No problem, too many times threads in forums start with a question with no resolution.
Old Jul 18, 2020
eqoicivic's Avatar
eqoicivic is an unknown quantity at this point
Is this the same problem with starter?
File Type: mov
Old Jul 18, 2020
Legofan's Avatar
No, you'll have to check the ignition switch, start relay and all associated wiring.
Old Jul 19, 2020
eqoicivic's Avatar
I replaced the relay under the dash just in case but it didn’t work. However, I kept on cranking and there was a burnt smell. I guess the starter definitely needs replacing. 👎
https://youtu.be/2RUhq7sXNBo
Josh Phillips
Jan 12, 2018 07:45 PM
civic_mechanic
Feb 21, 2017 07:48 PM
jimwe
Feb 6, 2013 10:28 PM
xylerium
Oct 31, 2011 09:32 AM
breault5
Dec 30, 2007 12:34 PM
